Configuring Protection Rules to Block or Allow Internet Border Traffic
After protection is enabled with no access control policy configured, CFW allows all traffic by default. You can configure protection rules to allow or block traffic from the Internet to cloud assets (inbound) and from cloud assets to the Internet (outbound). Refined control by IP address, region, and domain name is supported to meet public network access security, intrusion prevention, and compliance audit requirements, ensuring the security of north-south traffic of assets bound to EIPs.
This section describes how to configure protection rules for an Internet border firewall.
Protection Rule Description
The protected objects, actions, and application scenarios of protection rules are as follows.
| Name | Description |
| Protected object |
| Network type |
| Action |
| Scenario | You can configure protection rules in the following scenarios:
CAUTION: If your IP address is a back-to-source WAF IP address, you are advised to configure a protection rule or the whitelist to allow its access. Exercise caution when configuring a protection rule to block access, which may affect your services.
| Type | Description |
| Quota limit |
| Restrictions on domain name protection |
| Restrictions on regions | A protection rule with its source or destination set to a region (geographical location) takes effect only for IPv4 protected objects. |
| Restrictions on address groups |
| Other restrictions |
Impacts on Services
When configuring a blocking rule, if address translation or proxy is involved, evaluate the impact of blocking IP addresses with caution.
Adding an Internet Border Protection Rule
The procedures for adding a protection rule in scenarios are as follows.
- Enable EIP protection. For details, see Enabling Internet Border Traffic Protection.
- (Optional) To add multiple IP addresses and services (protocols, source ports, and destination ports), add their groups first.
- For details about how to add multiple IP addresses, see Managing IP Address Groups.
- For details about how to add multiple services, see Managing Service Groups.
- In the navigation pane of the CFW console, choose . The Internet Border Protection Rules page is displayed.
- Add a protection rule.
On the Protection Rules > EIP tab, click Add Rule. Configure protection parameters.
You can configure one or more types for a rule, but only the following type combinations are allowed:- IP address and IP address group
- IP address, IP address group, and network domain name
- IP address, IP address group, and network domain name group
- Application domain name and application domain name group
- Service and service group
Table 1 Internet boundary rule parameters (inbound direction) Parameter
IP Type
IP type of the security policy.
Name
Name of a custom protection rule. It must meet the following requirements:- It can contain 1 to 255 characters.
- The name can contain only letters, numbers, underscores (_), and hyphens (-).
Direction
Traffic direction of the protection rule. Select Inbound.- Inbound: Cloud assets (EIPs) are accessed from the Internet.
- Outbound: Cloud assets (EIPs) access the Internet.
Source
Set the party that initiates a session.- IP Address/IP address group/Countries and regions:
- IP address: Enter EIPs. This parameter can be configured in the following formats:
- A single EIP, for example, xx.xx.10.5
- Consecutive EIPs, for example, xx.xx.0.2-xx.xx.0.10
- EIP segment, for example, xx.xx.2.0/24
- Multiple inconsecutive IP addresses can be added one by one.
- IP address group. You can configure multiple EIPs.
If Direction is set to Inbound, a predefined address group can be configured as the source address.
For details about how to add a user-defined IP address group, see Adding an IP Address Group. For details about how to view a predefined IP address group, see Viewing a Predefined Address Group.
- Countries and regions: If Direction is set to Inbound, you can control access based on continents, countries, and regions.
- Any: any source address
Destination
Set the recipient of a session.- IP Address/IP address group:
For details about how to add a custom IP address group, see Adding a User-defined IP Address Group.
- Any: any destination address
Service
- Service/Service group:
- Service: Set Protocol, Source Port, and Destination Port.
- Protocol: The value can be TCP, UDP, or ICMP.
- Source/Destination Port: If Protocol is set to TCP or UDP, you need to set the port number.
To specify all the ports of an IP address, set Port to 1-65535.
You can specify a single port. For example, to manage access on port 22, set Port to 22.
To set a port range, use a hyphen (-) between the starting and ending ports. For example, to manage access on ports 80 to 443, set Port to 80-443.
- Service group: A collection of services (protocols, source ports, and destination ports).
For details about how to add a custom service group, see Adding a Service Group. For details about predefined service groups, see Viewing a Predefined Service Group.
- Any: any protocol type or port number
Application
(Optional) Configure protection rules for application-layer protocols.- When Service is set to Any, all application types are supported.
- If Service is set to Service and Protocol is set to TCP, TCP applications, such as HTTP and HTTPS, are supported.
- If Service is set to Service and Protocol is set to UDP, UDP applications, such as DNS and RDP, are supported.
Select an application-layer protocol based on the value of Protocol under Service. If no protocol is selected, this parameter is set to Any by default.
Protection Action
Set the action to be taken when traffic passes through the firewall.- Allow: Traffic is forwarded.
- Block: Traffic is not forwarded.
Status
Whether a protection rule is applied immediately.
: The policy takes effect immediately after being configured.
: The policy is disabled.
Priority
Set the priority of the rule. If multiple security policies are configured, the security policies will be matched based on their priorities. Once traffic matches a security policy, it will not be checked against others. Assign priorities carefully. Specific policies should take precedence over general ones.- Pin on top: indicates that the priority of the policy is set to the highest.
- Lower than the selected rule: indicates that the policy priority is lower than a specified rule.
A smaller value indicates a higher priority.
The default priority of the first protection rule is 1. You do not need to configure its priority.
Schedule Management
(Optional) Click Schedule Management to configure when the rule will be applied. Select a schedule or click Add Schedule to add one. For details, see Adding a Schedule.
Allow Long Connection
If only one service is configured in the current protection rule and Protocol is set to TCP or UDP, you can configure the service session aging time (unit: second).
Up to 50 rules can be configured with persistent connections.- Yes: Configure the persistent connection duration.
- No: Retain the default durations. The default connection durations for different protocols are as follows:
- TCP: 1800s
- UDP: 60s
Long Connection Duration
If Allow Long Connection is set to Yes, you need to set the persistent connection duration and set hour, minute, and second.
The duration range is 1 second to 1,000 days.
Tags
(Optional) Tags are used to identify rules. You can use tags to classify and search for protection rules.
(Optional) Usage and application scenario
- Click OK to complete the protection rule configuration.
If the source addresses of the protection rule contain a WAF back-to-source IP address, enter CONFIRM in the displayed dialog box and click OK.
After a protection rule is configured and enabled, it takes effect immediately.
- (Optional) To add multiple IP addresses, domain names, and services (protocols, source ports, and destination ports), add their groups first.
- For details about how to add multiple domain names, see Managing Domain Name Groups.
On the EIP tab, click Add Rule. In the displayed dialog box, configure parameters. For details, see Table 2.
Table 2 Internet boundary rule parameters (outbound direction) Parameter
IP Type
Name
Direction
Traffic direction of the protection rule. Select Outbound.- Inbound: Cloud assets (EIPs) are accessed from the Internet.
Source
Set the party that initiates a session.- IP Address/IP address group:
Destination
Set the recipient of a session.- IP Address/IP address group/Countries and regions/Domain name/Domain name group:
- Countries and regions: A continent, a country, or a region
- Domain name/Domain name group: Domain names or domain groups can be protected.
- Application Domain Name/Application Domain Name Group: One or multiple domain names or wildcard domain names can be protected. The setting applies to application-layer protocols, including HTTP, HTTPS, TLS1, SMTPS, and POP3S. Domain names are used for matching.
- Network Domain Name/Network Domain Name Group: One or multiple domain names. Applies to network-layer protocols and supports all protocols. The resolved IP addresses are used for matching.
NOTE:- To protect the domain names of HTTP, HTTPS, TLS1, SMTPS, and POP3S applications, you can select any options.
- To protect the wildcard domain names of HTTP, HTTPS, TLS1, SMTPS, or POP3S, you select any option under Application. (A wildcard domain name is in the format of *.Domain name. The wildcard character * matches any character or string. For example, *.example.com.)
- To protect a single domain name of other application types (such as FTP, MySQL, and SMTP), select Network and select any option from the drop-down list. (If Domain name is selected, up to 600 IP addresses can be resolved.)
- To protect multiple domain names of other application types (such as FTP, MySQL, and SMTP), select Network and Network Domain Name Group from the drop-down list.
- If you need to configure the wildcard domain names or application domain name groups of the HTTP, HTTPS, TLS1, SMTPS, and POP3S applications, and the network domain groups of other application types for the same domain name, ensure that the priority of the Network protection rule is higher than that of the Application protection rule.
- For details about application- and network-type domain names, see Managing Domain Name Groups.
- For details about how to verify the policy validity after the outbound HTTP or HTTPS domain name or domain name group is configured, see How Do I Verify the Validity of an Outbound HTTP/HTTPS Domain Name Protection Rule?
Service
Application
(Optional) Configure a protection rule for application-layer protocols. This parameter is mandatory when Destination is set to Domain name/Domain name group.- When Service is set to Any, all application types are supported.
Protection Action
Status
Priority
Schedule Management
Tags
Viewing Protection Rule Hits
After your services run for a period of time, you can view the number of rule hits in the Hits column of the protection rule list.
You can click a number in the Hits column to go to the Access Control Logs tab page and view log details. For details, see Log Query.
Follow-up Operations
- Policy hits: For details about the protection overview, see Viewing Protection Information Using the Policy Assistant. For details about logs, see Viewing Attack Event Logs.
- For details about the traffic trend and statistics, see Traffic Center. For details about traffic records, see Log Query.
Related Operations/Documents
After adding a protection rule, you can edit, delete, and adjust the priority of the rule in the rule list.
- For details about how to add protection rules in batches, see Importing and Exporting Protection Policies.
- For details about how to adjust rule priority, see Adjusting the Priority of a Protection Rule.
- For details about how to manage protection rules, such as checking, editing, and deleting rules, see Managing Protection Rules.
