Velero
Velero is an add-on that backs up and restores Kubernetes cluster resources and persistent volumes. It stores application and service data in OBS buckets, providing both local and remote backup capabilities.
Velero can be used to:
- Back up clusters for disaster recovery.
- Migrate cluster resources to other clusters.
- Replicate production cluster data to development and test environments.
Open-source community: https://github.com/velero-io/velero
Documentation: https://velero.io/docs/main/
A CCE standard or Turbo cluster v1.29 or later is available.
- If you have deployed the community version of Velero in your cluster, uninstall it before installing the CCE Velero add-on. Otherwise, installation may fail.
- After Velero is uninstalled, related CRDs and custom resources (such as ConstraintTemplates and Constraints) are retained, along with your cluster backup data.
Installing the Add-on
- In the navigation pane, choose Add-ons. Locate Velero on the right and click Install.
- On the Install Add-on page, configure the specifications as needed.
Velero runs on a single pod. Running multiple pods concurrently may lead to split-brain and data write conflicts, leading to corrupted backups or failed restorations. The single-pod deployment ensures state consistency and data security.
- If you select Preset, choose an option based on your cluster size. CCE automatically configures the number of add-on pods and resource quotas according to the selected specification. You can view these configurations on the console.
- If you selected Custom, you can adjust the number of pods and resource quotas as needed.
If your cluster is large and the preset specifications do not meet your needs, you can customize resource specifications. Estimate the number of pods in the cluster to determine the add-on's memory requirements before customizing resource specifications. The recommended memory request and limit for typical large clusters can be calculated as follows:
- CPU limit = Number of resources in the cluster/10,000 x N (N = 500m; if the number of resources in the cluster is greater than 20,000, N = 400m)
For example, if there are 20,000 resources in the cluster, the CPU limit is 1000m (2 × 500m).
- Memory limit = Number of resources in the cluster × YAML size per resource (KB)/10,000 x 55 MiB
For example, if there are 20,000 resources and the YAML size of each resource is 15 KB, the memory limit is 1650 MiB (2 × 15 × 55 MiB). (The calculated value may differ from the recommended value in Table 1. Either value may be used.)
- The requested CPU and memory should be at least 1/4 of the limit.
Table 1 Recommended add-on memory sizes in large-scale scenarios Cluster Resources (15 KB for Each Resource YAML)
Recommended CPU Request
Recommended CPU Limit
Recommended Memory Request
Recommended Memory Limit
10000
125m
500m
200 MiB
800 MiB
20000
250m
1000m
500 MiB
2000 MiB
50000
500m
2000m
1000 MiB
4000 MiB
100000
1000m
4000m
2000 MiB
8000 MiB
200000
2000m
8000m
4000 MiB
16000 MiB
- Configure Agency Settings. Add-ons require access to other cloud services during runtime. You must configure an add-on agency to authorize these operations. For details, see Custom Agencies for Add-ons.
- Create automatically: CCE automatically creates a default agency and assigns it to the add-on. If a default agency already exists, CCE will not create another one.
- Use existing: Choose an agency from the drop-down list. Ensure that the selected agency has the required permissions. Otherwise, the add-on may not function properly.
- Configure the add-on parameters.
Table 2 Extended parameter settings Parameter
annotations
Add annotations to Velero workloads. By default, this parameter is left blank.
tenant_id
The parameter value is automatically populated with the project ID. Do not change this value when running the add-on.
cluster_id
- Configure deployment policies for the add-on pods.
When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
Table 3 Configurations for add-on scheduling Parameter
Node Affinity
- Not configured: Node affinity is disabled for the add-on pods.
- Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
- Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
- Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
Toleration
Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
The add-on applies default tolerations for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints. The toleration time window is 60 seconds.
For details, see Configuring Tolerance Policies.
- Click Install.
Components
| Component | Description | Resource Type |
| velero | The core component that backs up and restores Kubernetes cluster resources and PVs. | Deployment |
How to Use
After installing Velero, you can back up and restore cluster applications in Cluster Backup. For details about features and operations, see Cluster Backup.
Release History
| Add-on Version | Supported Cluster Version | New Feature | Community Version |
| 1.35.26 | v1.35 | Fixed some issues. | |
| 1.35.10 | v1.35 | Support for cluster backup |
| 1.34.26 | v1.34 | Fixed some issues. | |
| 1.34.10 | v1.34 | Support for cluster backup |
| 1.33.26 | v1.33 | Fixed some issues. | |
| 1.33.10 | v1.33 | Support for cluster backup |
| 1.32.26 | v1.32 | Fixed some issues. | |
| 1.32.10 | v1.32 | Support for cluster backup |
| 1.31.26 | v1.31 | Fixed some issues. | |
| 1.31.10 | v1.31 | Support for cluster backup |
| 1.30.26 | v1.30 | Fixed some issues. | |
| 1.30.10 | v1.30 | Support for cluster backup |
