Help Center/ Cloud Container Engine/ User Guide/ Networking/ Gateway API/ Envoy Gateway/ Using Envoy AI Gateway to Route Large Model Inference Traffic
Updated on 2026-09-29 GMT+08:00
Envoy AI Gateway is a cloud-native traffic gateway add-on designed for large language models (LLMs) and AI applications. Built on the high-performance Envoy proxy, it serves as a data plane component for AI traffic, providing unified traffic routing, load balancing, and traffic governance for AI inference services in Kubernetes clusters.
With this add-on, you can seamlessly proxy and manage API requests to heterogeneous large models (such as OpenAI, ERNIE Bot, Qwen, and locally deployed open-source models), improving the reliability and governance efficiency of AI application architectures.
This section provides an example of using the AI Gateway to route traffic based on model names.
How It Works
Envoy AI Gateway uses a control plane–data plane architecture:
  • Control plane:
    • Includes the Envoy Gateway Controller and AI Gateway Controller.
    • Listens for AI Gateway resources (such as AIGatewayRoute) submitted by users and generates configurations.
    • Communicates with Envoy via the Extension Server protocol, fine-tunes xDS configuration before delivery, and injects AI-specific routing logic.
  • Data plane:
    • The core component is the Envoy proxy.
    • Typically deployed in sidecar mode or as an independent gateway.
    • The built-in AI Gateway ExtProc (External Processing) handles AI-specific service logic (such as KV cache routing and multi-model load balancing).
    The following figure shows the overall architecture of this deployment example.
  • A cluster of v1.32 or later is available.
  • Envoy Gateway is installed in the current cluster with AI Inference Gateway enabled.
If the node cannot access the Internet, replace the node image with an appropriate custom image.
  1. Obtain and deploy the simulated vLLM model (Llama3-8b).
    # vLLM simulation backend
    wget https://github.com/kubernetes-sigs/gateway-api-inference-extension/raw/v1.0.1/config/manifests/vllm/sim-deployment.yaml
    # InferenceObjective
    wget https://raw.githubusercontent.com/kubernetes-sigs/gateway-api-inference-extension/refs/tags/v1.0.1/config/manifests/inferenceobjective.yaml
    # InferencePool resources
    wget https://github.com/kubernetes-sigs/gateway-api-inference-extension/raw/v1.0.1/config/manifests/inferencepool-resources.yaml
    # Apply all resources.
    kubectl apply -f .
  2. Obtain and deploy the simulated Mistral model.
    1. Create mistral-inference-deploy.yaml.
      apiVersion: v1
      kind: Service
        namespace: default
        selector:
          app: mistral-upstream
        ports:
          - protocol: TCP
            port: 8080
            targetPort: 8080
        # The headless service allows the IP addresses of the pods to be resolved via the Service DNS.
        clusterIP: None
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 3
        selector:
          matchLabels:
        template:
            labels:
            containers:
              - name: testupstream
                image: docker.io/envoyproxy/ai-gateway-testupstream:latest
                imagePullPolicy: IfNotPresent
                ports:
                  - containerPort: 8080
                env:
                  - name: TESTUPSTREAM_ID
                    value: test
                readinessProbe:
                  httpGet:
                    path: /health
                    port: 8080
                  initialDelaySeconds: 1
                  periodSeconds: 1
      apiVersion: inference.networking.k8s.io/v1
      kind: InferencePool
        namespace: default
        targetPorts:
          - number: 8080
        selector:
          matchLabels:
        endpointPickerRef:
          port:
            number: 9002
      apiVersion: inference.networking.x-k8s.io/v1alpha2
      kind: InferenceObjective
        namespace: default
        priority: 10
        poolRef:
          # Bind the InferenceObjective to the InferencePool.
      apiVersion: v1
      kind: Service
        namespace: default
        selector:
          app: mistral-epp
        ports:
          - protocol: TCP
            port: 9002
            targetPort: 9002
            appProtocol: http2
        type: ClusterIP
      apiVersion: v1
      kind: ServiceAccount
        namespace: default
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        labels:
          app: mistral-epp
        replicas: 1
        selector:
          matchLabels:
            app: mistral-epp
        template:
            labels:
              app: mistral-epp
            serviceAccountName: mistral-epp
            # Conservatively, this timeout should mirror the longest grace period of the pods within the pool
            terminationGracePeriodSeconds: 130
            containers:
              - name: epp
                image: registry.k8s.io/gateway-api-inference-extension/epp:v1.0.1
                args:
                  - --pool-name
                  - "mistral"
                  - "--pool-namespace"
                  - "default"
                  - --v
                  - "4"
                  - --zap-encoder
                  - "json"
                  - --grpc-port
                  - "9002"
                  - --grpc-health-port
                  - "9003"
                  - "--config-file"
                  - "/config/default-plugins.yaml"
                ports:
                  - containerPort: 9002
                  - containerPort: 9003
                  - name: metrics
                    containerPort: 9090
                livenessProbe:
                  grpc:
                    port: 9003
                    service: inference-extension
                  initialDelaySeconds: 5
                  periodSeconds: 10
                readinessProbe:
                  grpc:
                    port: 9003
                  periodSeconds: 10
                volumeMounts:
                  - name: plugins-config-volume
                    mountPath: "/config"
            volumes:
                configMap:
      apiVersion: v1
      kind: ConfigMap
        namespace: default
      data:
        default-plugins.yaml: |
          apiVersion: inference.networking.x-k8s.io/v1alpha1
          kind: EndpointPickerConfig
          plugins:
          - type: queue-scorer
          - type: kv-cache-utilization-scorer
          - type: prefix-cache-scorer
          schedulingProfiles:
          - name: default
            plugins:
            - pluginRef: queue-scorer
            - pluginRef: kv-cache-utilization-scorer
            - pluginRef: prefix-cache-scorer
      kind: Role
        namespace: default
      rules:
        - apiGroups: ["inference.networking.x-k8s.io"]
          resources: ["inferenceobjectives", "inferencepools"]
          verbs: ["get", "watch", "list"]
        - apiGroups: ["inference.networking.k8s.io"]
          resources: ["inferencepools"]
        - apiGroups: [""]
          resources: ["pods"]
      kind: RoleBinding
        namespace: default
      subjects:
        - kind: ServiceAccount
          namespace: default
      roleRef:
        apiGroup: rbac.authorization.k8s.io
        kind: Role
      kind: ClusterRole
      rules:
        - apiGroups:
            - authentication.k8s.io
          resources:
            - tokenreviews
          verbs:
            - create
        - apiGroups:
            - authorization.k8s.io
          resources:
            - subjectaccessreviews
          verbs:
            - create
      kind: ClusterRoleBinding
      subjects:
          namespace: default
      roleRef:
        kind: ClusterRole
    2. Deploy the Mistral simulation service.
      kubectl apply -f mistral-inference-deploy.yaml
  3. Obtain and use an AIServiceBackend to deploy a traditional backend.
    1. Create backend-deployment.yaml.
      apiVersion: aigateway.envoyproxy.io/v1alpha1
      kind: AIServiceBackend
        namespace: default
        schema:
        backendRef:
          kind: Backend
          group: gateway.envoyproxy.io
      apiVersion: gateway.envoyproxy.io/v1alpha1
      kind: Backend
        namespace: default
        endpoints:
          - fqdn:
              hostname: envoy-ai-gateway-basic-testupstream.default.svc.cluster.local
              port: 80
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 1
        selector:
          matchLabels:
            app: envoy-ai-gateway-basic-testupstream
        template:
            labels:
            containers:
                ports:
                env:
                    value: test
                readinessProbe:
                  httpGet:
                    path: /health
                    port: 8080
                  periodSeconds: 1
      apiVersion: v1
      kind: Service
        namespace: default
        selector:
        ports:
          - protocol: TCP
            port: 80
            targetPort: 8080
        type: ClusterIP
    2. Deploy traditional backend services.
      kubectl apply -f backend-deployment.yaml
  4. Deploy a Gateway.
    1. Create ai-gateway-config.yaml.
      kind: EnvoyProxy
        namespace: envoy-gateway-system
        provider:
          type: Kubernetes
          kubernetes:
            envoyService:
              type: NodePort
            envoyDeployment:
              container:
                image: docker.io/envoyproxy/envoy:distroless-dev
      apiVersion: gateway.networking.k8s.io/v1
      kind: GatewayClass
        controllerName: gateway.envoyproxy.io/gatewayclass-controller
        parametersRef:
          kind: EnvoyProxy
      kind: Gateway
        namespace: default
        gatewayClassName: inference-pool-with-aigwroute
        listeners:
          - name: http
            protocol: HTTP
            port: 80
      kind: AIGatewayRoute
        namespace: default
        parentRefs:
          - name: inference-pool-with-aigwroute
            kind: Gateway
            group: gateway.networking.k8s.io
        rules:
          # Route for vLLM Llama model via InferencePool
          - matches:
              - headers:
                  - type: Exact
                    value: meta-llama/Llama-3.1-8B-Instruct
            backendRefs:
              - group: inference.networking.k8s.io
                kind: InferencePool
          # Route for Mistral model via InferencePool
          - matches:
              - headers:
                  - type: Exact
                    value: mistral:latest
            backendRefs:
                kind: InferencePool
          # Route for traditional backend (non-InferencePool)
          - matches:
              - headers:
                  - type: Exact
                    value: some-cool-self-hosted-model
            backendRefs:
              - name: envoy-ai-gateway-basic-testupstream
    2. Deploy the Gateway.
      kubectl apply -f ai-gateway-config.yaml
  5. Verify the deployment.
    1. Access the cluster console. In the navigation pane, choose Workloads. In the right pane, click the Deployments tab and check whether all workloads are Running.
    2. On the Services tab, verify that the required Services have been created.
      On this page, obtain and record the access address and NodePort of the corresponding Service, and combine them in the format [access-address]:[NodePort]. In all subsequent tests, replace $GATEWAY_IP in the configuration with this address.
  6. Test the Gateway's capability of routing requests to different models or backends.
    1. Test the Llama-3 model route.
      Verify route forwarding from the Gateway to Llama-3.
      curl -H "Content-Type: application/json" \
        -d '{
              "model": "meta-llama/Llama-3.1-8B-Instruct",
              "messages": [
                      "role": "user",
                      "content": "Hi. Say this is a test"
        http://$GATEWAY_IP/v1/chat/completions
      If information similar to the following is returned, the model is working:
      {"choices":[{"finish_reason":"stop","index":0,"message":{"content":"The temperature there is twenty-five degrees centigrade. Give a man a fish and you feed him for a day; Teach a man to fish",role":"assistant"}}],"created":1767755896,"do_remote_decode":false,"do_remote_prefill":false,"id":"chatcmp-561ca69e-9716-411f-9656-7a96d9******","model":"meta-llama/llama-3.1-8B-Instruct","object":"chat.completion","remote_block_id":"","remote_engine_id":"","remote_host":"","remote_port":0,"usage":{"completion_tokens":28,"prompt_tokens":7,"total_tokens":35},
    2. Test the Mistral model route.
      Verify route forwarding from the Gateway to Mistral.
        -d '{
              "model": "mistral:latest",
              "messages": [
                      "role": "user",
      {"choices":[{"message":{"content":"This is a test.","role":"assistant"}}]}
    3. Test the common backend load balancer route.
      Verify route forwarding from the Gateway to the custom backend load balancer.
        -d '{
              "model": "some-cool-self-hosted-model",
              "messages": [
                      "role": "user",
      {"choices":[{"message":{"role":"assistant","content":"I am the captain of my soul."}}]}
