Help Center/ Cloud Container Engine/ User Guide/ Networking/ Gateway API/ Envoy Gateway/ Function Comparison Between Envoy Gateway and NGINX Ingress
Updated on 2026-09-29 GMT+08:00
In CCE clusters, Envoy Gateway (with Envoy as the data plane) and NGINX Ingress are both used for external traffic routing and load balancing. This section compares Envoy Gateway and NGINX Ingress to help you select the appropriate solution and plan migration.
Traffic Routing
Basic Routing
NGINX Ingress (Via Annotations)
Envoy Gateway (Via Gateway API)
Difference
Host routing
Supported
Envoy Gateway uses HTTPRoute hostnames to implement this function.
Path routing (prefix/exact)
Supported
Envoy Gateway uses HTTPRoute rules.matches.path to implement this function.
Configuring HTTPS certificates
Supported
Envoy Gateway uses Gateway listeners.tls to reference a secret and implement this function.
Redirecting HTTP to HTTPS
Supported
Envoy Gateway uses the HTTPRoute RequestRedirect filter to implement this function.
Forwarding to multiple backends
Supported
Envoy Gateway uses HTTPRoute backendRefs to support multiple backends.
Multi-port listening
Supported
Envoy Gateway uses Gateway listeners to implement this function.
Configuring HTTPS backend Services
Supported
Envoy Gateway uses the extension resource BackendTLSPolicy to implement this function.
Configuring gRPC backend Services
Supported
This function is implemented using GRPCRoute. For details, see https://gateway.envoyproxy.io/latest/tasks/traffic/grpc-routing/.
Request/Response Modification
Difference
Path rewriting
Supported
Envoy Gateway uses the HTTPRoute URLRewrite filter to implement this function.
Redirection
Supported
Request header modification
Supported
Envoy Gateway uses the HTTPRoute RequestHeaderModifier filter to implement this function.
Response header modification
Supported
Envoy Gateway uses the HTTPRoute ResponseHeaderModifier filter to implement this function.
Custom Nginx snippet injection
Not supported
Not supported by Envoy Gateway natively. Use EnvoyPatchPolicy to modify the underlying Envoy configuration.
Upstream Policies
Difference
Timeout
Supported
Envoy Gateway uses HTTPRoute timeouts or BackendTrafficPolicy resources.
The implementation differs from NGINX: Envoy Gateway provides a more granular timeout mechanism with different configuration fields.
Retry
Supported
Envoy Gateway uses BackendTrafficPolicy resources with the following fields:
  • retry.numRetries: maximum number of retries allowed.
  • retry.retryOn: conditions under which retries are triggered.
  • retry.perRetry.timeout: timeout for an individual retry attempt.
Load balancing algorithms (such as RR and least_request)
Supported
Envoy Gateway uses BackendTrafficPolicy loadBalancer.type with the following options:
  • LeastRequest: Two instances are randomly selected by default, and the request is forwarded to the one with fewer active requests.
  • ConsistentHash: consistent hashing.
  • Random: random distribution.
  • RoundRobin: sequential polling.
Connection pool and circuit breaker
Supported
Envoy Gateway uses BackendTrafficPolicy circuitBreaker with the following fields:
  • circuitBreaker.maxConnections: maximum number of TCP connections between Envoy and the upstream service.
  • circuitBreaker.maxParallelRequests: maximum number of concurrent requests between Envoy and the upstream service. When this threshold is reached, new requests are rejected.
Sticky session (cookie stickiness)
Supported
Envoy Gateway uses consistent hashing for load balancing combined with the StatefulSession extension to implement this function.
Grayscale Release and Traffic Control
Difference
Traffic distribution by weight
Supported
Envoy Gateway uses HTTPRoute backendRefs.weight to implement this function.
Traffic distribution by header/query
Supported
Envoy Gateway supports both headers and query parameters in HTTPRoute matches.
Traffic distribution by cookie
Supported
Envoy Gateway uses HTTPRoute matches (matching the cookie header) to implement this function.
Traffic mirroring
Supported
Envoy Gateway uses the HTTPRoute RequestMirror filter to implement this function.
Cross-origin access
Supported
CORS can be configured using SecurityPolicy. For details, see https://gateway.envoyproxy.io/latest/tasks/security/cors/.
Security
TLS Encryption Configuration
Difference
TLS version/cipher suite
Supported
Envoy Gateway uses ClientTrafficPolicy resources for fine-grained TLS configuration.
Authentication
Difference
Basic authentication
Supported
Envoy Gateway uses SecurityPolicy basicAuth to implement this function.
External authentication (OAuth2/OIDC/SSO)
Supported
Envoy Gateway uses SecurityPolicy oidc to implement this function.
Path/Method-based RBAC
Supported
Envoy Gateway uses SecurityPolicy authorization to implement this function.
Rate Limiting and Protection
Difference
Rate limiting (by IP, header, or key)
Supported
Envoy Gateway supports both global and local rate limiting via BackendTrafficPolicy.
Max connections or concurrent connections
Partially supported
Envoy Gateway uses ClientTrafficPolicy and BackendTrafficPolicy resources to implement this function.
IP whitelist or blacklist
Supported
