Using a Temporary Custom Access Key (AK/SK) to Mount an OBS Volume
In containerized application deployment, mounting an OBS bucket into a container still requires a permanent AK/SK. Because these credentials never expire, they broaden the blast radius of any leak and clash with the least-privilege policies that security-focused enterprises now enforce. The container-storage add-on (CCE Container Storage (Everest)) eliminates the need for permanent AK/SKs by generating a short-lived, custom AK/SK each time an OBS volume is mounted. Unlike the permanent AK/SKs held by IAM users, these credentials are created on demand, expire in 15 minutes to 24 hours, and are then automatically deleted, eliminating the long-term risk of a leaked key.
- The CCE Container Storage (Everest) version must be 2.4.204 or later.
- The cluster version must be 1.28 or later.
Notes and Constraints
- When an OBS volume is mounted using a temporary custom AK/SK, you must periodically refresh that credential before it expires. Otherwise, service containers will not be able to access the mounted OBS volume.
- Temporary custom AK/SKs cannot be configured for secure containers.
- Once an OBS volume has been mounted with a temporary AK/SK, the credential type cannot be switched to a permanent one. In this case, dynamic key replacement is not supported.
- The temporary AK/SK inherits the exact OBS read/write permissions of the IAM user who requested it, so that user must already hold those rights.
Creating a Secret Using Access Keys
- Obtain temporary access keys (AK/SK and STS token). For details, see Temporary Access Key (for Federated Users).
- Encode each credential in Base64. (Assume that the AK is xxx, the SK is yyy, and the STS token is zzz.)
echo -n xxx|base64 echo -n yyy|base64 echo -n zzz|base64 -w 0
Record the encoded AK/SK and STS token.
- Create a YAML file, for example test-user.yaml, to hold the secret.
apiVersion: v1 data: access.key: WE5WWVhVNU***** secret.key: Nnk4emJyZ0***** security.token: Adfaf***** kind: Secret metadata: name: test-user namespace: default labels: secret.kubernetes.io/used-by: csi type: cfe/secure-opaqueThe parameters are as follows.
access.key
The Base64-encoded AK
secret.key
The Base64-encoded SK
security.token
The Base64-encoded STS token
name
The secret name
namespace
The namespace of the secret
The label required so the console can use this secret when provisioning an OBS PV/PVC.
type
The secret type. The value must be cfe/secure-opaque.
When this type is used, user input is encrypted automatically.
- Create the secret.
kubectl create -f test-user.yaml
Mounting a Secret to an OBS Volume
The method of mounting an OBS volume varies depending on how the volume was created.
After a secret is created using the AK/SK, you can associate the secret with the PV to be created and then use the AK/SK in the secret to mount an OBS volume.
- Log in to the OBS console, create an OBS bucket, and record the bucket name and StorageClass. The parallel file system is used as an example.
- Create a YAML file for the PV, for example, pv-example.yaml.
apiVersion: v1 kind: PersistentVolume metadata: name: pv-obs-example annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner spec: accessModes: - ReadWriteMany capacity: storage: 1Gi csi: nodePublishSecretRef: name: test-user namespace: default driver: obs.csi.everest.io fsType: obsfs volumeAttributes: everest.io/obs-volume-type: STANDARD everest.io/region: ap-southeast-1 storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner volumeHandle: obs-normal-static-pv persistentVolumeReclaimPolicy: Delete storageClassName: csi-obsParameter
Secret specified during the mounting.
- name: name of the secret
- namespace: namespace of the secret
fsType
File type, which can be s3fs or obsfs. If the value is s3fs, an OBS bucket is created. If the value is obsfs, an OBS parallel file system is created.
volumeHandle
OBS volume name.
- Create a PV.
kubectl create -f pv-example.yaml
After a PV is created, you can create a PVC and associate it with the PV.
- Create a YAML file for the PVC, for example, pvc-example.yaml.
Example YAML file for the PVC:
apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: csi.storage.k8s.io/node-publish-secret-name: test-user csi.storage.k8s.io/node-publish-secret-namespace: default volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner everest.io/obs-volume-type: STANDARD csi.storage.k8s.io/fstype: obsfs name: obs-secret namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 1Gi storageClassName: csi-obs volumeName: pv-obs-exampleParameter
Secret name
Namespace of the secret
- Create a PVC.
kubectl create -f pvc-example.yaml
After the PVC is created, you can create a workload and associate it with the PVC to create volumes.
When dynamically creating an OBS volume, you can use the following method to specify a secret:
apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: csi.storage.k8s.io/node-publish-secret-name: test-user csi.storage.k8s.io/node-publish-secret-namespace: default everest.io/obs-volume-type: STANDARD csi.storage.k8s.io/fstype: obsfs name: obs-secret namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 1Gi storageClassName: csi-obsParameter
Secret name
- Create a PVC.
Verification
- Query the name of the workload pod.
kubectl get pod | grep obs-secret
Expected outputs:
obs-secret-5cd558f76f-vxslv 1/1 Running 0 3m22s
- Query the objects in the mount path. In this example, the query is successful.
kubectl exec obs-secret-5cd558f76f-vxslv -- ls -l /temp/ - Write data into the mount path. In this example, the write operation failed.
kubectl exec obs-secret-5cd558f76f-vxslv -- touch /temp/testExpected outputs:
touch: setting times of '/temp/test': No such file or directory command terminated with exit code 1
- Set the read/write permissions for the IAM user who mounted the OBS volume by referring to the bucket policy configuration.
- Write data into the mount path again. In this example, the write operation succeeded.
kubectl exec obs-secret-5cd558f76f-vxslv -- touch /temp/test - Check the mount path in the container to see whether the data is successfully written.
kubectl exec obs-secret-5cd558f76f-vxslv -- ls -l /temp/Expected outputs:
-rwxrwxrwx 1 root root 0 Jun 7 01:52 test
