Updated on 2026-09-21 GMT+08:00
Comparison of Workload Security Group Configuration Methods
In CCE Turbo clusters, pods can be directly bound to security groups using VPC network interfaces or supplementary network interfaces. CCE Turbo provides multi-dimensional security group binding methods to meet your service needs.
Security groups can be associated with workloads through multiple methods: annotations, security group policies, node pool settings, or pod network settings. When multiple methods are used, only the highest-priority method applies. (Lower values in the table below indicate higher priority.)
Table 1 Comparison between methods for configuring workload security groups
Priority
How to Configure
Application and Advantage
Constraint
Binding a Security Group to a Pod Using an Annotation
  • This method is suitable for debugging services.
  • Security groups added using this method can be used by other configuration methods.
  • Newly added security groups apply only to new pods. To apply the configuration to existing pods, they must be rebuilt.
  • Pre-bound container network interfaces cannot be associated with a target security group.
2
Binding a Security Group to a Workload Using a Security Group Policy
  • This method applies to the entire namespace and requires workloads within the namespace.
  • Security group settings can be updated for pods in real time. This eliminates the need to rebuild existing pods.
3
Using Node Pool Settings to Bind the Default Security Group to Pods in the Node Pool
  • Services are classified by node pool. You may need to configure associated scheduling policies based on your services.
  • Pre-bound container network interfaces can be associated with a target security group.
  • Only newly bound container network interfaces on the node can be associated with a target security group.
4
Binding a Subnet and Security Group to a Namespace or Workload Using a Container Network Configuration
  • This method applies to the entire cluster and supports multiple namespaces.
  • Security groups can be configured with subnets.
5
Default network interface security group of a Turbo cluster (For details about security group rules, see Security Group Rules in a CCE Turbo Cluster That Uses the Cloud Native 2.0 Network Model.)
  • This method is the default configuration. If your cluster requires general security hardening, you can directly modify the rules in the default security group.
None
