Updated on 2026-09-21 GMT+08:00
Configuring GZIP Data Compression for a LoadBalancer Service
LoadBalancer Services support data compression, which reduces the size of files to be transferred, improves file transfer efficiency, and reduces the bandwidth needed for the transmission.
  • Data compression requires ELB. Before using this function, check whether it is supported by ELB in the current region.
  • After data compression is configured, if you delete the data compression configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
  • A Kubernetes cluster is available and the cluster version meets the following requirements:
    • v1.23: v1.23.14-r0 or later
    • v1.25: v1.25.9-r0 or later
    • v1.27: v1.27.6-r0 or later
    • v1.28: v1.28.4-r0 or later
    • Other clusters of later versions
Creating a LoadBalancer Service and Configuring GZIP Data Compression
Use one of the following methods.
  2. In the navigation pane, choose Services and Ingresses. In the upper right corner, click Create Service.
    In this example, only mandatory parameters for configuring SNI are listed. Retain the default settings for other parameters. For details, see Using the CCE Console.
  3. Configure basic parameters.
    Example
    Service Type
    Select LoadBalancer.
    None
    Service Name
    Enter a name, which can be the same as the workload name.
    nginx
    Namespace
    Select the namespace that the workload belongs to.
    default
    Selector
    Add the key and value of a pod label. The Service will be associated with the workload pods based on the label and direct traffic to the pods with this label.
    You can also click Reference Workload Label to use the label of an existing workload. In the dialog box displayed, select a workload and click OK.
    app:nginx
  4. Configure load balancer parameters.
    Example
    Load Balancer
    Select a load balance type and how the load balancer will be created. To enable HTTP/HTTPS on the listener port of a dedicated load balancer, the type of the load balancer must be Application (HTTP/HTTPS) or Network (TCP/UDP/TLS) & Application (HTTP/HTTPS).
    • Use existing: Only the load balancers in the same VPC as the cluster can be selected. If no load balancer is available, click Create Load Balancer to create one on the ELB console.
    • Auto create: The load balancer will be created in the VPC that the cluster belongs to. For details, see Table 1.
    An existing Dedicated load balancer of the Network (TCP/UDP/TLS) & Application (HTTP/HTTPS) type
  5. Configure access parameters.
    Example
    Service Affinity
    Whether to route external traffic to a local node or a cluster-wide endpoint. For details, see Service Affinity (externalTrafficPolicy).
    • Cluster-level: The IP addresses and ports of all nodes in a cluster can access the workload associated with the Service. However, accessing the Service may result in performance deterioration due to route redirection, and the client's source IP address may not be obtainable.
    • Node-level: Only the IP address and port of the node where the workload is located can access the workload associated with the Service. Accessing the Service will not result in performance deterioration due to route redirection, and the client's source IP address can be obtained.
    Cluster-level
    Port
    • Protocol: the protocol used by the Service. According to the Kubernetes implementation, if a Service uses a load balancer with a non-UDP protocol, this parameter must be set to TCP and the corresponding listener frontend protocol must be selected. For details, see Protocols for Services.
    • Container Port: the port that the workload listens on. For example, Nginx uses port 80 by default.
    • Service Port: the port used by the Service.
      • Listen on a port: The port ranges from 1 to 65535.
      • Listen on ports: ELB allows you to create listeners that listen on ports within specified ranges. Each listener can support up to 10 non-overlapping port ranges.
        To configure port ranges for load balancer listeners, ensure the following conditions are met:
        • The cluster version must be v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later.
        • A dedicated load balancer must be used with TCP/UDP/TLS selected.
        • This function requires ELB. Before using this function, check whether ELB supports full-port listening and forwarding for layer-4 protocols in the current region.
    • Frontend Protocol: Set the protocol of the load balancer listener for establishing connections with clients. When a dedicated load balancer is selected, HTTP/HTTPS can be configured only when Application (HTTP/HTTPS) is selected and TLS can be configured only when Network (TCP/UDP/TLS) is selected.
    When a LoadBalancer Service is created, a random node port number (NodePort) is automatically generated.
    • Protocol: TCP
    • Container Port: 80
    • Service Port: 80
    • Frontend Protocol: HTTP
  6. Configure listener parameters.
    Constraint
    Example
    Data Compression
    If this function is enabled, specific files will be compressed. If it is not enabled, files will not be compressed.
    • Brotli can compress all file formats.
    • GZIP can compress the files in the following format:
      text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, or application/json
    This parameter is available only if HTTP or HTTPS is used as the frontend protocol of a dedicated load balancer listener.
    Enable
  7. Click Create.
This section uses an existing load balancer as an example. An example YAML file of a Service with data compression enabled is as follows:
apiVersion: v1
kind: Service
  labels:
    app: nginx
  namespace: default
  annotations:
    kubernetes.io/elb.class: performance                              # Load balancer type, which can only be performance (dedicated load balancer)
    kubernetes.io/elb.id: 35cb350b-23e6-4551-ac77-10d5298f5204        # ID of an existing load balancer
    kubernetes.io/elb.protocol-port: http:80                          # The HTTP port 80 is used.
    kubernetes.io/elb.gzip-enabled: 'true'                            # Enable data compression.
  selector:
    app: nginx
  externalTrafficPolicy: Cluster
  ports:
    - name: cce-service-0
      targetPort: 80
      nodePort: 0
      port: 80
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: **.**.**.**    # IP address of the load balancer
Table 1 Key parameters
Type
String
  • true: Data compression is enabled, and specific file types will be compressed.
  • false: Data compression is disabled, and no files will be compressed. By default, data compression is disabled.
The files in the following format can be compressed:
  • GZIP can compress the files of the following types: text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, and application/json
This function is available only for HTTP/HTTPS listeners of dedicated load balancers.
Verifying Configuration
  2. In the navigation pane, choose Services and Ingresses. Locate the row that contains the created Service and click the load balancer name to go to the ELB console.
  3. Switch to the Listeners tab, click the listener name of the created port, and check whether the option is enabled.
