Help Center/ Cloud Container Engine/ User Guide/ Storage/ SFS Turbo/ (Recommended) Creating an SFS Turbo Subdirectory Using a Dynamic PV
Updated on 2026-01-28 GMT+08:00
There is a minimum capacity limit when you create an SFS Turbo volume, so you are not billed based on the capacity you have used. By default, when you mount an SFS Turbo volume to a workload, the root directory of the volume is mapped to the containers. The actual capacity used by the workload is far lower than the limit, which wastes resources. CCE enables efficient utilization of storage capacity by creating SFS Turbo subdirectories dynamically when you create a PVC. If your Everest version is 2.4.73, you can configure the capacities of these subdirectories. This allows multiple workloads to share the SFS Turbo file system.
  • You have created a cluster and installed the CCE Container Storage (Everest) add-on of v2.3.23 or later in the cluster.
  • To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
  • You have created an available SFS Turbo file system, and the SFS Turbo file system and the cluster are in the same VPC.
Notes and Constraints
If the cluster version is v1.23 or later, SFS Turbo supports dynamic capacity expansion when used without subdirectories or with limited subdirectories.
Notes and Restrictions on Subdirectory Quotas
  • If the subdirectory quota is less than 1 GiB, it is automatically set to 1 GiB. The maximum quota cannot exceed the capacity of the target SFS Turbo file system. The minimum scale-out step is 1 GiB, and capacity reduction is not allowed.
  • Once a subdirectory quota is configured, it cannot be canceled.
  • The number of files or subdirectories in a file system is determined by the quota capacity (in KB) divided by 16. The upper limit is set at 1 billion and cannot be changed by users.
Dynamically Creating an SFS Turbo Subdirectory
CCE allows you to create SFS Turbo subdirectory PVCs via the console or kubectl based on the configured StorageClasses. After PVC creation, CCE dynamically allocates storage resources and mounts the PVCs to the specified workloads. To do so, perform the following operations.
  2. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
    PVC Type
    In this example, select SFS Turbo.
    PVC Name
    Enter the PVC name, which must be unique in a namespace.
    Creation Method
    Select New subdirectory.
    Storage Classes
    Choose csi-sfsturbo. You can customize a StorageClass and configure its reclaim policy and binding mode. For details, see Through the Console.
    Access Mode
    SFS Turbo volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
    SFS Turbo
    Click Select SFS Turbo. On the displayed page, select the SFS Turbo file system that meets your requirements and click OK.
    Subdirectory
    Enter the absolute path of a subdirectory, for example, /a/b.
    Subdirectory Reclaim Policy
    Determine whether to retain subdirectories when a PVC is deleted.
    • Retain: When a PVC is deleted, the PV is deleted, but its associated subdirectories are retained.
    • Delete: When a PVC is deleted, the PV and its associated subdirectories are also deleted.
      When a subdirectory is deleted, only the absolute path of the subdirectory specified in the PVC is deleted. The parent directory is retained.
    Subdirectory Capacity
    • Not limited: The subdirectory capacity is not limited.
    • Limited: The subdirectory capacity is limited.
    Capacity
    The maximum capacity of the subdirectory, in GiB. This parameter is available only when the subdirectory capacity limit is enabled.
  3. Click Create to create a PVC and a PV.
    You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tabs, respectively.
  1. Use kubectl to access the cluster.
  2. Create the pvc-sfsturbo-subpath.yaml file.
    apiVersion: v1
    kind: PersistentVolumeClaim
      name: pvc-sfsturbo-subpath    # PVC name
      namespace: default
      annotations:
        everest.io/volume-as: absolute-path                # An SFS Turbo subdirectory is used.
        everest.io/sfsturbo-share-id: <sfsturbo_id>        # SFS Turbo ID
        everest.io/path: /a                                # Subdirectory that is automatically created, which must be an absolute path
        everest.io/reclaim-policy: retain-volume-only      # When a PVC is deleted, the PV is deleted, but its associated subdirectories are retained.
        everest.io/csi.enable-sfsturbo-dir-quota: "true"   # The status of quota limit
      accessModes:
        - ReadWriteMany      # ReadWriteMany must be selected for SFS Turbo.
      resources:
        requests:
          storage: 10Gi      # For SFS Turbo subdirectory PVCs, this configuration specifies the capacity of a subdirectory when quota limit is enabled. In other scenarios, it is only used for verification and must not be empty or 0.
      storageClassName: csi-sfsturbo     # StorageClass name of the SFS Turbo file system
    Table 1 Key parameters
    Mandatory
    Yes
    The value is fixed at absolute-path, indicating that a dynamically created SFS Turbo subdirectory is used.
    Yes
    SFS Turbo ID
    How to obtain: Log in to the CCE console, choose Service List > Storage > Scalable File Service, and select SFS Turbo. In the list, click the name of the target SFS Turbo file system. On the details page, copy the content following ID.
    everest.io/path
    Yes
    Subdirectory that is automatically created, which must be an absolute path.
    Yes
    Whether to retain subdirectories when deleting a PVC. This parameter must be used with PV Reclaim Policy. This parameter is available only when the PV reclaim policy is Delete. Options:
    • retain-volume-only: When a PVC is deleted, the PV is deleted, but its associated subdirectories are retained.
    • delete: When a PVC is deleted, the PV and its associated subdirectories are also deleted.
    No
    Whether to enable quota limit for a subdirectory. If the value is set to true, the limit is enabled. If the value is empty or set to any other value, the limit is disabled.
    storage
    Yes
    Requested capacity in the PVC, in Gi.
    • When subdirectory capacity limit is enabled (everest.io/csi.enable-sfsturbo-dir-quota is set to true), storage indicates the capacity of a subdirectory, and its value must be an integer.
      If storage is set to a decimal, the value will be rounded up automatically. For example, if storage is set to 10.1Gi, an 11-GiB subdirectory will be created.
    • If a subdirectory capacity is not limited, this parameter is meaningless and only used for verification. You can set this parameter to a fixed value 10Gi.
  3. Run the following command to create a PVC:
    kubectl apply -f pvc-sfsturbo-subpath.yaml
Helpful Links
If a storage volume fails to mount to a workload, rectify the fault by referring to What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
