Grafana
Updated on 2025-02-18 GMT+08:00
Introduction
Grafana is an open-source visualized data monitoring platform. It provides you with various charts and panels for real-time monitoring, analysis, and visualization of various metrics and data sources.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons, locate Grafana on the right, and click Install.
  2. Configure Specifications of the add-on pods. You can adjust their CPU and memory quotas as needed.
  3. Configure the add-on parameters.
    Table 1 Grafana parameters
    PVC Type
    To install Grafana, create a storage volume to store local data. When Grafana is uninstalled, this storage volume will not be deleted.
    • If you selected EVS, you need to select an EVS disk type. The EVS disk types supported by different regions may vary. You can select one disk type on the management console.
      EVS disks are charged by storage capacity and occupy your EVS disk quotas.
    • If you selected DSS, you need to select a DSS pool. The created storage volume will be in the corresponding storage pool.
    Capacity (GiB)
    Expand the disk capacity after the disk is created. The EVS disk size is 5 GiB by default. For details, see Related Operations.
    Interconnecting Data Sources with AOM
    Enable this function to report Prometheus data to AOM. After this function is enabled, you can select the corresponding AOM instance. The collected basic metrics are free of charge. Custom metrics are charged by AOM. For details, see Product Pricing Details. To interconnect with AOM, you must have certain permissions. Only Huawei Cloud accounts, HUAWEI IDs, and users in the admin user group can perform this operation.
    Public Access
    This option is available in Grafana 1.2.1 or later versions. After it is enabled, you need to select a load balancer as the Grafana service entry. Only load balancers in the VPC to which the cluster belongs can be selected. If a dedicated load balancer is used, you must configure network specifications for it.
    NOTICE:
    If you allow public access, Grafana services will be exposed to the public network. It is recommended that you assess the security risks and establish access control policies.
  4. Configure deployment policies for the add-on pods.
    Table 2 Configurations for add-on scheduling
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on.
    • Specify node: Specify the nodes where the add-on is deployed. If you do not specify the nodes, the add-on will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on is deployed. If you do not specify the node pools, the add-on will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on is to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on will be randomly scheduled based on the default cluster scheduling policy.
    Toleration
    Using both taints and tolerations allows (not forcibly) the add-on Deployment to be scheduled to a node with the matching taints, and controls the Deployment eviction policies after the node where the Deployment is located is tainted.
    The add-on adds the default tolerance policy for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints, respectively. The tolerance time window is 60s.
    For details, see Configuring Tolerance Policies.
  5. Click Install.
    After the add-on is installed, select the cluster and choose Add-ons in the navigation pane. On the displayed page, view the add-on in the Add-ons Installed area.
Components
Table 3 Add-on components
Component
Resource Type
grafana
This component provides the data visualization capability for Grafana.
Deployment
How to Use
To access Grafana charts through a public network, you need to bind a LoadBalancer service to the Grafana container.
  1. Log in to the CCE console, and click the name of the cluster with the Grafana add-on installed to access the cluster console. On the displayed page, choose Services & Ingresses in the navigation pane.
  2. Click Create from YAML in the upper right corner to create a public network LoadBalancer Service for Grafana.
    apiVersion: v1
    kind: Service
      name: grafana-lb     # Service name, which is customizable
      namespace: monitoring
      labels:
        app: grafana
      annotations:
        kubernetes.io/elb.id: 038ff***     # Replace it with the ID of the public network load balancer in the VPC that the cluster belongs to.
      ports:
        - name: cce-service-0
          protocol: TCP
          port: 80     #Service port, which can be customized.
          targetPort: 3000     # Default Grafana port. Retain the default value.
      selector:
        app: grafana
      type: LoadBalancer
  3. After the creation, visit load balancer public IP:Service port to access Grafana and select a proper dashboard to view the aggregated data.
    Figure 1 Grafana panel
Change History
Table 4 Release history
Add-on Version
Supported Cluster Version
New Feature
1.3.1
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Clusters 1.31 are supported.
1.3.0
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Clusters 1.30 are supported.
1.2.1
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Supported association with the LoadBalancer Services.
1.2.0
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Clusters 1.29 are supported.
1.1.0
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
v1.28
Supported the open-source Grafana.
