Redirecting HTTP to HTTPS for a LoadBalancer Ingress
Updated on 2025-01-07 GMT+08:00
Ingresses can forward HTTP access requests to HTTPS listeners. The following is an example for redirecting the requests for accessing example.com/test of an ingress to HTTPS port 443.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.14-r0 or later
    • v1.25: v1.25.9-r0 or later
    • v1.27: v1.27.6-r0 or later
    • v1.28: v1.28.4-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
Ingresses support HTTP to HTTPS redirection only when dedicated load balancers are used.
You can configure HTTP to HTTPS redirection using either the CCE console or kubectl.
  2. Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for redirecting HTTP to HTTPS. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
    Dedicated
    Listener
    • External Protocol: HTTP and HTTPS are available.
    • External Port: specifies the port of the load balancer listener.
      After configuration, this setting cannot be modified in clusters of a version earlier than v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, or v1.30.4-r0. In clusters of v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later, this setting can be modified.
    • Redirect to HTTPS: After this function is enabled, you can configure the HTTPS port.
      • External Port: Enter an HTTPS port.
      • Certificate Source: TLS secret and ELB server certificates are supported.
      • Server Certificate: Use a certificate created on ELB.
        If no certificate is available, go to the ELB console and create one. For details, see Adding a Certificate.
    • External Port: 80
    • Redirect to HTTPS: enabled
      • External Port: 443
      • Certificate Source: ELB server certificate
      • Server Certificate: cert-test
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service or create a Service. Any Services that do not match the search criteria will be filtered out automatically.
    • Destination Service Port: Select the access port of the destination Service.
    • Domain Name: You do not need to configure this parameter.
    • Path Matching Rule: RegEx match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    Figure 1 Redirecting HTTP to HTTPS
    Figure 2 Configuring a port for redirecting HTTP to HTTPS
  4. Click OK.
You can use annotations to redirect the requests of an ingress to an HTTPS listener. The following is an example:
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.id: df76342f-e898-402a-bac8-bde5bf974da8
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'             # Multi-port configuration
        kubernetes.io/elb.ssl-redirect: 'true'        # Enable redirection from HTTP to HTTPS.
        kubernetes.io/elb.tls-certificate-ids: 6cfb43c9de1a41a18478b868e34b0a82       # HTTPS listener server certificate
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
      ingressClassName: cce
    Table 2 Key parameters
    Mandatory
    Type
    Yes
    String
    Multi-port listening configuration. After configuration, this setting cannot be modified in clusters of a version earlier than v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, or v1.30.4-r0. In clusters of v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later, this setting can be modified.
    Format: The value is a JSON string, for example:
    Parameter: The port number ranges from 1 to 65535.
    You can configure this annotation along with the one for enabling HTTP/2, but HTTP/2 takes effect only on HTTPS ports.
    Yes
    String
    Whether to enable redirection from HTTP to HTTPS.
    Format: The value can be true or false.
    Parameter: true indicates that redirection is enabled. If the value is false or the parameter is unavailable, redirection is disabled.
    Either this annotation or the annotation of a grayscale release can be configured.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/test-redirect-listener created
  4. Check the created ingress.
    kubectl get ingress
    NAME                    CLASS    HOSTS     ADDRESS          PORTS   AGE
    test-redirect-listener  cce      *         121.**.**.**     80      10s
    Example
    Name
    ingress-test
    Load Balancer
    Dedicated
    Listener
    • External Port: 80
    Forwarding Policy
    • Path: /
  4. Click OK.
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
    Mandatory
    Type
    Yes
    String
    Yes
    String
    kubectl get ingress
