Updated on 2026-09-21 GMT+08:00
Draining a Node
After you enable node drainage via the console, kubectl, or API, CCE configures the node to be non-schedulable and evicts all pods that comply with Rules for Draining Nodes on the node. New pods will not be scheduled to this node.
If a node fails, you can quickly drain the node to isolate it from the workload. The evicted pods will be rescheduled to healthy nodes by the workload controller.
To ensure service availability during drainage, specify a disruption budget for your application. Otherwise, the application may become unavailable during pod rescheduling.
  • A cluster is available and the cluster version meets the following requirements:
    • v1.21: v1.21.10-r0 or later
    • v1.23: v1.23.8-r0 or later
    • v1.25: v1.25.3-r0 or later
    • Versions later than v1.25
  • To drain a node as an IAM user, you must have at least one of the following permissions (for details, see Configuring Namespace Permissions (Kubernetes RBAC-based)):
    • cluster-admin (administrator): read and write permissions on all resources in all namespaces.
    • drainage-editor: drain a node.
    • drainage-viewer: view the nodal drainage status but cannot drain a node.
When a node is drained, all pods on the node will be safely evicted. However, CCE will take specific actions for pods that meet certain filtering criteria.
Filter Criterion
Forced Drainage Enabled
Forced Drainage Disabled
The status.phase field of the pod is Succeeded or Failed.
Deletion
Deletion
The pod is not managed by the workload controller.
Deletion
Drainage cancellation
The pod is managed by DaemonSet.
None
For clusters v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later, if forcible drainage is not used for DaemonSet pods, the default operation is None.
A volume of the emptyDir type is mounted to the pod.
Eviction
The pod is a static pod directly managed by the kubelet
None
None
The following operations may be performed on pods during node drainage:
  • Deletion: The pod is deleted from the current node and will not be rescheduled to other nodes.
  • Eviction: The pod is deleted from the current node and rescheduled to another node.
  • None: The pod will not be evicted or deleted.
  • Drainage cancellation: If a pod on a node cancels drainage, the drainage process of the node is terminated and no pod is evicted or deleted.
This section describes how to drain nodes.
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
  3. Locate the target node and choose More > Drain Node in the Operation column.
  4. In the Drain Node window, configure the parameters.
    • Timeout (s): Node drain tasks automatically fail after the specified timeout expires. A value of 0 indicates that task will not time out.
    • Forcible Drain: If this function is enabled, pods managed by DaemonSet will be ignored, and pods with emptyDir volumes and pods not managed by controllers will be deleted. For details, see Rules for Draining Nodes.
  5. Click OK and wait until the node drainage is complete.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Edit the YAML file for drainage.
    The following is an example of Drainage-test.yaml:
    apiVersion: node.cce.io/v1
    kind: Drainage
      name: 192.168.1.67-1721616409999   # Drainage resource name
      nodeName: 192.168.1.67     # Kubernetes name of the node to be drained, which can be obtained by running the kubectl get node command
      force: true
      timeout: 0
    • nodeName: node to be drained. The parameter value is the node name in Kubernetes, not the name displayed on the console.
      You can run the kubectl get node command to obtain a node name in Kubernetes.
    • force: whether to forcibly drain a node. Value true means that the drainage is forced, while false means it is not.
    • timeout: timeout measured in seconds. Node drain tasks automatically fail after the specified timeout expires. A value of 0 indicates that task will not time out.
  3. Create drainage resources.
    kubectl create -f Drainage-test.yaml
    If information similar to the following is displayed, the drainage resources have been created:
    drainage.node.cce.io/192.168.1.67-1721616409999 created
  4. Check the result.
    kubectl get drainages 192.168.1.67-1721616409999 -o yaml
    If phase is Succeeded, the operation is successful.
    kind: Drainage
      creationTimestamp: "2024-07-22T03:12:56Z"
      generation: 1
      resourceVersion: "2683143"
      uid: 3ec131e4-0505-4c88-8255-ef9d0eb02712
      force: true
      timeout: 0
    status:
      conditions:
      - lastTransitionTime: "2024-07-22T03:12:56Z"
        message: start to drain node
        reason: Started
        status: "True"
        type: Started
      - lastTransitionTime: "2024-07-22T03:13:26Z"
        message: node has been drained
        reason: Succeeded
        status: "True"
        type: Finished
      phase: Succeeded
  1. Obtain the token in the region where the cluster is located. For details, see Authentication.
  2. Based on the API format, find the URL for the node drainage API.
    URL of the API for draining a node:
    https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages
    • {clusterid}: cluster ID, which can be obtained on the Overview page of the CCE console.
    • Endpoint: endpoint of CCE in the region where the cluster is located.
      For details about its value, see Regions and Endpoints.
      For example, the endpoint of CCE in the AP-Singapore region is cce.ap-southeast-3.myhuaweicloud.com.
  3. Use the POST request method and configure request header parameters.
    curl --location --request POST 'https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages' \
    --header 'Content-Type: application/json' \
    --header 'X-Auth-Token: MIIWvw******' \
    --data @Drainage.json
    The following table lists the header parameters contained in the request.
    Table 1 Request header parameters
    Mandatory
    Type
    Content-Type
    Yes
    String
    Message body type (format), for example, application/json.
    X-Auth-Token
    Yes
    String
    Use a token to call the API. For details about how to obtain a token, see Authentication.
    Drainage.json is located in the current directory and contains the following content:
        "apiVersion": "node.cce.io/v1",
        "kind": "Drainage",
        "metadata": {
            "name": "192.168.1.67-1721616404940"
        "spec": {
            "nodeName": "192.168.1.67",
            "force": true,
            "timeout": 0
Cancelling Node Drainage
This section describes how to stop a node drainage that is currently in progress.
In clusters v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions, node drainage can be canceled.
This operation will abort drainage on nodes, but workloads that have been evicted from these nodes will not be automatically migrated back.
  3. Locate the node that is being drained and click Cancel Drainage.
  4. In the displayed dialog box, click OK. The node status changes to Drainage canceled. You can click Enable Scheduling to restore the node to the schedulable state.
  2. Check drainage resources.
    Command output:
    NAME                         AGE
    192.168.1.67-1721616409999   13s
  3. Cancel drainage.
    kubectl annotate drainages 192.168.1.67-1721616409999 node.cce.io/drainage-disable=true
    In the command output, phase is changed to Cancelled.
    kind: Drainage
      annotations:
        node.cce.io/drainage-disable: "true"
      generation: 1
      resourceVersion: "2689858"
      force: true
      timeout: 0
    status:
      conditions:
        reason: Started
        status: "True"
        type: Started
        reason: Succeeded
        status: "True"
        type: Finished
      - lastTransitionTime: "2024-07-22T03:37:48Z"
        message: node drainage has been cancelled
        reason: Cancelled
        status: "True"
        type: Cancelled
      phase: Cancelled
    URL of the API for canceling node drainage:
    https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages/{drainageName}
    • {drainageName}: name of the drainage resource, which can be obtained by running the kubectl get drainages command.
  3. Use the PATCH request method and configure request header parameters.
    curl --location --request PATCH 'https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages/{drainageName}' \
    --header 'Content-Type: application/merge-patch+json' \
    --data @Drainage-cancel.json
    Table 2 Request header parameters
    Mandatory
    Type
    Content-Type
    Yes
    String
    Message body type. The value is application/merge-patch+json in PATCH format.
    X-Auth-Token
    Yes
    String
    Drainage-cancel.json is located in the current directory and contains the following content:
        "metadata": {
            "annotations": {
                "node.cce.io/drainage-disable": "true"
