Updated on 2026-09-21 GMT+08:00
New Nodes
Check Items
Check whether nodes can be created in the cluster.
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab and then Create Node. For details about the node configuration, see Creating a Node.
    Figure 1 Creating a node
Solution
If nodes cannot be created in your cluster after the cluster is upgraded, contact technical support.
