Updated on 2026-05-26 GMT+08:00
Compatibility Risks
Check Items
Read the version compatibility differences and ensure that they are not affected. The patch upgrade does not involve version compatibility differences.
Version Compatibility
Upgrade Path
Version Difference
Self-Check
All upgrade paths
Pay attention to Kubernetes API changes. For details, see Deprecated APIs.
Check the API version used in the cluster. Do not use a deprecated API version. Change the API version to the one recommended in Deprecated APIs.
From v1.28 to v1.29 or v1.31
In Kubernetes 1.29, the startup behavior of kube-proxy has been modified. This update allows kube-proxy to use a value smaller than the node sysctl setting. For example, if the kernel value of nf_conntrack_max on a node is set to 1000000, but kube-proxy calculates a value of 131072, the value 131072 calculated by kube-proxy will be used. Community PR: https://github.com/kubernetes/kubernetes/pull/120448
This issue may occur on nodes that generate a large number of connections, such as gateway nodes. Check whether the value of nf_conntrack_max has been changed to a large value (for example, 4294967295 or 1000000) using sysctl. After a node is upgraded, the value calculated by kube-proxy is used, and the parameter is overwritten with a smaller value (100,000+ or 200,000+), which affects traffic during peak hours.
Configure conntrack-min using kube-proxy of the node pool instead of modifying the OS kernel parameter nf_conntrack_max. For details, see Configuring a Node Pool.
v1.23 or v1.25
Upgraded to v1.27
Docker is no longer recommended. Use containerd instead. For details, see Container Runtimes.
This item has been included in the pre-upgrade check.
v1.21 or v1.19
Upgraded to v1.23
For the NGINX Ingress Controller of an earlier version (community version v0.49 or earlier, corresponding to CCE nginx-ingress version v1.x.x), the ingress type is not specified as nginx during ingress creation. This means the ingress can also be managed by NGINX Ingress Controller even if kubernetes.io/ingress.class: nginx is not added to annotations. However, for the NGINX Ingress Controller of a later version (community version v1.0.0 or later, or CCE nginx-ingress version v2.x.x), the ingresses created without specifying the Nginx type will not be managed by the NGINX Ingress Controller, and ingress rules will become invalid, which interrupts services.
This item has been included in the pre-upgrade check. You can also perform the self-check by referring to NGINX Ingress Controller.
v1.19 to v1.21
The bug of exec probe timeouts is fixed in Kubernetes v1.21. Before this bug is fixed, the exec probe does not consider the timeoutSeconds field. Instead, the probe will run indefinitely, even beyond its configured deadline. It will stop until the result is returned. If this field is not specified, the default value 1 is used. This field takes effect after the upgrade. If the probe runs over 1 second, the application health check may fail and the application may restart frequently.
Before the upgrade, check whether the timeout is properly set for the exec probe.
kube-apiserver of CCE v1.19 or later requires that the Subject Alternative Names (SANs) field be configured for the certificate of your webhook server. Otherwise, kube-apiserver fails to call the webhook server after the upgrade, and containers cannot be started properly.
Root cause: X.509 CommonName is discarded in Go v1.15. kube-apiserver of CCE v1.19 is compiled using Go v1.15. If your webhook certificate does not have SANs, kube-apiserver does not process the CommonName field of the X.509 certificate as the host name by default. As a result, the authentication fails.
Before the upgrade, check whether the SAN field is configured in the certificate of your webhook server.
  • If you do not have your own webhook server, you can skip this check.
  • If the field is not set, use the SAN field to specify the IP address and domain name supported by the certificate.
v1.15 to v1.19
The control plane of CCE v1.19 clusters is incompatible with kubelet v1.15. When a node fails to upgrade or restarts after the master node has been successfully upgraded, it is likely to enter the NotReady state.
This is because kubelet restarts and attempts to re-register the node, but the default registration labels (failure-domain.beta.kubernetes.io/is-baremetal and kubernetes.io/availablezone) used in v1.15 are considered invalid by v1.19 kube-apiserver.
The valid labels in v1.19 clusters are node.kubernetes.io/baremetal and failure-domain.beta.kubernetes.io/zone.
  1. In normal cases, this scenario is not triggered.
  2. After the master node is upgraded, do not suspend the upgrade so the node can be quickly upgraded.
  3. If a node fails to be upgraded and cannot be restored, evict applications on the node as soon as possible. Contact technical support and skip the node upgrade. After the upgrade is complete, reset the node.
In CCE v1.15 and v1.19 clusters, the Docker storage driver file system has been changed from XFS to Ext4. As a result, the import package sequence may be abnormal in the pods of upgraded Java application, leading to pod exceptions.
Before the upgrade, check the Docker configuration file /etc/docker/daemon.json on the node. Check whether the value of dm.fs is xfs.
  • If the value is ext4 or the storage driver is Overlay, you can skip the next steps.
  • If the value is xfs, you are advised to deploy applications in the cluster of the new version in advance to test whether the applications are compatible with the new cluster version.
      "storage-driver": "devicemapper",
      "storage-opts": [
      "dm.thinpooldev=/dev/mapper/vgpaas-thinpool",
      "dm.use_deferred_removal=true",
      "dm.fs=xfs",
      "dm.use_deferred_deletion=true"
Root cause: X.509 CommonName is discarded in Go v1.15. kube-apiserver of CCE v1.19 is compiled using Go v1.15. The CommonName field is processed as the host name. As a result, the authentication fails.
NOTICE:
To mitigate the impact of version differences on cluster upgrade, CCE performs special processing during the upgrade from v1.15 to v1.19 and still supports certificates without SANs. However, no special processing is required for subsequent upgrades. You are advised to rectify your certificate as soon as possible.
In clusters v1.17.17 and later, CCE automatically creates pod security policies (PSPs) for you, which restrict the creation of pods with unsafe configurations, for example, pods for which net.core.somaxconn under a sysctl is configured in the security context.
After an upgrade, you can allow insecure system configurations as required. For details, see Configuring a Pod Security Policy.
If an init container or Istio is used in the in-place upgrade of a cluster v1.15, pay attention to the following restrictions:
In kubelet v1.16 and later versions, QoS classes are different from those in earlier versions. In kubelet v1.15 and earlier versions, only containers in spec.containers are counted. In kubelet v1.16 and later versions, containers in both spec.containers and spec.initContainers are counted. The QoS class of a pod will change after the upgrade. As a result, the container in the pod restarts.
You are advised to modify the QoS class of the service container before the upgrade to avoid this problem. For details, see Table 1.
Table 1 QoS class changes before and after the upgrade
Init Container (Calculated Based on spec.initContainers)
Service Container (Calculated Based on spec.containers)
Pod (Calculated Based on spec.containers and spec.initContainers)
Impacted or Not
Guaranteed
BestEffort
Burstable
Yes
Guaranteed
Burstable
Burstable
No
Guaranteed
Guaranteed
Guaranteed
No
BestEffort
BestEffort
BestEffort
No
BestEffort
Burstable
Burstable
No
BestEffort
Guaranteed
Burstable
Yes
Burstable
BestEffort
Burstable
Yes
Burstable
Burstable
Burstable
No
Burstable
Guaranteed
Burstable
Yes
