Help Center/ Cloud Container Engine/ User Guide/ Nodes/ Management Nodes/ Changing the Billing Mode of a Node to Yearly/Monthly
Updated on 2026-06-16 GMT+08:00
Nodes in CCE clusters can be billed on a pay-per-use or yearly/monthly basis. A pay-per-use node can be changed to yearly/monthly-billed.
Notes and Constraints
  • To change the billing mode of a node in a pay-per-use node pool to yearly/monthly, you need to upgrade the cluster to v1.19.16-r40, v1.21.11-r0, v1.23.9-r0, v1.25.4-r0, or later.
  • After a node in a pay-per-use node pool is changed to a yearly/monthly node, the node does not support elastic scale-in.
  • The billing modes of resources like EVS disks and EIPs used by pay-per-use nodes cannot be changed simultaneously. For details, see Pay-per-Use to Yearly/Monthly.
  • To change a pay-per-use node in a node pool to a yearly/monthly one, locate the target node in the node list, choose More > Forbid node pool scale-in above the list, and change the billing mode to yearly/monthly.
To change the billing mode of a node from pay-per-use to yearly/monthly, perform the following operations:
  2. In the navigation pane, choose Nodes. In the right pane, click the Nodes tab, locate the row containing the target node, and choose More > Change Billing Mode in the Operation column. In the dialog box displayed, click OK.
    Figure 1 Changing the billing mode of a node to yearly/monthly
  3. Wait for the resource checks and the order generation, click OK to go to the Billing Center, and submit the order.
    Figure 2 Generating an order
  4. Select the resources whose billing modes are to be changed to yearly/monthly, set the required duration, enable auto-renew, and click Pay.
    Figure 3 Changing the billing mode from pay-per-use to yearly/monthly
