Accessing the Internet from a Container
Containers can access the Internet in either of the following ways:
- Bind an EIP to the node where the container is located if the network model is VPC or tunnel.
- Bind an EIP to the target pod if the cluster uses a Cloud Native 2.0 network. For details, see Configuring an EIP for a Pod in a CCE Turbo Cluster.
- Configure SNAT rules through NAT Gateway.
NAT Gateway provides source network address translation (SNAT) for VPC pods, translating private IP addresses to the EIP's public IP address. Pods in the VPC share this EIP for Internet access. Figure 1 shows the SNAT architecture. SNAT allows the pods in a VPC to access the Internet without being bound to EIPs. SNAT supports a large number of concurrent connections, which makes it suitable for applications involving a large number of requests and connections.
This section describes how to use a NAT gateway for Internet access.
- Obtain an EIP. For details, see Assigning an EIP
- Log in to the EIP console.
- On the EIPs page, click Buy EIP.
- Configure parameters as required.
Set Region to the region where container pods are located.
Figure 2 Buying an EIP
- Create a NAT gateway. For details, see Using a Public NAT Gateway to Enable Servers to Share One or More EIPs to Access the Internet.
- Click
in the upper left corner and choose Networking > NAT Gateway in the expanded list. - On the Public Network Gateways page, click Buy Public NAT Gateway in the upper right corner.
Select the same VPC.
Figure 3 Buying a NAT gateway
- Click
- Configure an SNAT rule and bind the EIP to the subnet. For details, see Using a Public NAT Gateway to Enable Servers to Share One or More EIPs to Access the Internet.
- On the page displayed, click the name of the NAT gateway for which you want to add the SNAT rule.
- On the SNAT Rules tab, click Add SNAT Rule.
SNAT rules take effect by CIDR block. As different container network models use different communication modes, the subnet needs to be selected according to the following rules:
- Tunnel network and VPC network: Select the subnet where the node is located, that is, the subnet selected during node creation.
If there are multiple CIDR blocks, you can create multiple SNAT rules or customize a CIDR block as long as the CIDR block contains the node subnet.
Figure 4 Adding an SNAT rule
After the SNAT rule is configured, workloads can access the Internet from the container. The Internet can be pinged from the container.
