Configuring QoS for a Pod
Bandwidth preemption occurs between different containers deployed on the same node, which may cause service jitter. You can configure bandwidth limitation for the pod to solve this problem.
Specifications
| Specifications | Tunnel Network | VPC Network | Cloud Native Network 2.0 | VPC + DataPlane V2 | Cloud Native Network 2.0 + DataPlane V2 |
| Supported cluster versions | All versions | Clusters v1.19.10 and later | Clusters v1.19.10 and later | Cluster version: v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, or later | Clusters v1.34.3-r10 or later |
| Egress bandwidth limitation | Supported | Supported | Supported | Supported | Supported |
| Ingress bandwidth limitation | Supported | Supported | Supported | Supported in clusters v1.28.15-r80, v1.29.15-r40, v1.30.14-r0, v1.32.9-r0, v1.33.7-r0, and later versions | Supported |
| Scenarios where bandwidth limitation is not supported | None | None |
| Mutual access between pods on the host node | None |
| Bandwidth limitation range | The value must be specified in either Mbit/s or Gbit/s, for example, 100 Mbit/s or 1 Gbit/s. The minimum allowable value is 1 Mbit/s. The maximum value is 4.29 Gbit/s for clusters running versions earlier than v1.28.15-r70, v1.29.15-r30, v1.30.14-r30, v1.31.10-r30, v1.32.6-r30, v1.33.5-r20, or v1.34.1-r0. Clusters v1.28.15-r70, v1.29.15-r30, v1.30.14-r30, v1.31.10-r30, v1.32.6-r30, v1.33.5-r20, v1.34.1-r0, and later versions: The minimum value is 1 kbit/s, and the maximum value is 1 Pbit/s. | The minimum value is 1 kbit/s, and the maximum value is 1 Pbit/s. | The minimum value is 1 kbit/s, and the maximum value is 1 Pbit/s. | ||
- eBPF-based bandwidth limiting is available only when DataPlane V2 is enabled in the VPC network. Other network models use TBF qdisc for bandwidth limiting.
- Pod bandwidth limitation applies only to regular containers. Secure containers do not support this feature.
- Pod bandwidth limitation does not apply to hostNetwork pods.
Using the CCE Console
When creating a workload on the console, you can set pod ingress and egress bandwidth limits by clicking Network Configuration in the Advanced Settings area.
Using kubectl
apiVersion: apps/v1
kind: Deployment
namespace: default
labels:
app: test
replicas: 2
selector:
matchLabels:
app: test
template:
labels:
app: test
annotations:
kubernetes.io/ingress-bandwidth: 100M
kubernetes.io/egress-bandwidth: 100M
containers:
- name: container-1
image: nginx:alpine
imagePullPolicy: IfNotPresent
imagePullSecrets:
- name: default-secret - kubernetes.io/ingress-bandwidth: ingress bandwidth limit on pods
- kubernetes.io/egress-bandwidth: egress bandwidth limit on pods
If these two parameters are not specified, the bandwidth is not limited.
After modifying the ingress or egress bandwidth limit of a pod, restart the container for the modification to take effect. After annotations are modified in a pod not managed by workloads, the container will not be restarted, so the bandwidth limits do not take effect. You can create a pod again or manually restart the container.
