Configuring Passthrough Networking for a LoadBalancer Service
Applications
kube-proxy, which is responsible for forwarding intra-cluster traffic, adds the IP addresses of load balancers associated with the LoadBalancer Services to nodes' local forwarding rules by default. When a client from within a cluster accesses the IP address of a load balancer, the traffic is directly forwarded to the destination instead of being forwarded by the load balancer.
If node-level affinity is configured for a Service (with externalTrafficPolicy set to Local), the Service will forward traffic only to pods on the hosting node. When a node or pod accesses another pod in the same cluster, if the node where the client runs does not have the corresponding backend pod, the access may fail.
Solution
CCE supports passthrough networking. You can configure the kubernetes.io/elb.pass-through annotation for the LoadBalancer Services so that the load balancers forward the intra-cluster access to the IP addresses of the load balancers associated with the Services to their backend pods.
- CCE standard clusters
When a LoadBalancer Service is accessed from within the cluster, traffic is routed to the backend pods using iptables or IPVS by default.
When a LoadBalancer Service (configured with elb.pass-through) is accessed from within the cluster, traffic is first forwarded to the load balancer, then to the nodes, and finally routed to the backend pods using iptables or IPVS.
- CCE Turbo clusters
When a LoadBalancer Service is accessed from within the cluster via a NodeIP, traffic is routed to the backend pods using iptables or IPVS by default.
When a LoadBalancer Service is accessed from a pod within the cluster, passthrough will be used by default. The client connects to the load balancer's private IP address, and traffic is routed directly to the pods through the load balancer.
Notes and Constraints
- In a CCE standard cluster, after passthrough networking is configured using a dedicated load balancer, the private IP address of the load balancer cannot be accessed from the node where a workload pod resides or other pods on the same node as the workload.
- This function is only available in clusters v1.19 and later.
- In IPVS, the passthrough settings of Services connected to the same load balancer must be the same.
- If node-level (local) service affinity is used, kubernetes.io/elb.pass-through is automatically set to onlyLocal to enable passthrough networking.
This section describes how to create a Deployment using an Nginx image and create a Service with passthrough networking enabled.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Use the Nginx image to create a Deployment.
Create an nginx-deployment.yaml file. The file content is as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 2 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - image: nginx:latest name: container-0 resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secretDeploy the workload.kubectl create -f nginx-deployment.yaml - Create a LoadBalancer Service and set kubernetes.io/elb.pass-through to true. For details about how to create a LoadBalancer Service, see LoadBalancer. The content of the nginx-elb-svc.yaml file is shown below. In this example, a shared load balancer named james is automatically created.
apiVersion: v1 kind: Service metadata: annotations: kubernetes.io/elb.pass-through: "true" kubernetes.io/elb.class: union kubernetes.io/elb.autocreate: '{"type":"public","bandwidth_name":"cce-bandwidth","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}' labels: app: nginx name: nginx spec: externalTrafficPolicy: Local ports: - name: service0 port: 80 protocol: TCP targetPort: 80 selector: app: nginx type: LoadBalancer - Create the Service.
kubectl create -f nginx-elb-svc.yaml
Verification
- Log in to the ELB console and check the load balancer (named james in this example) associated with the Service.
- Click the load balancer name and click the Monitoring tab.
There are 0 connections to the load balancer.
- Log in to an Nginx container in the cluster using kubectl and access the IP address of the load balancer.
- Obtain the Nginx containers in the cluster.
kubectl get pod
Information similar to the following is displayed:NAME READY STATUS RESTARTS AGE nginx-7c4c5cc6b5-vpncx 1/1 Running 0 9m47s nginx-7c4c5cc6b5-xj5wl 1/1 Running 0 9m47s
- Log in to an Nginx container.
kubectl exec -it nginx-7c4c5cc6b5-vpncx -- /bin/sh - Access the load balancer IP address.
curl **.**.**.**
- Wait for a while and check the monitoring data on the ELB console.
If a new access connection is displayed, the load balancer can forward access as expected.
