Automatically Creating an OBS Volume Through kubectl
Updated on 2025-02-18 GMT+08:00
During the use of OBS, expected OBS buckets can be automatically created and mounted as volumes. Currently, standard and infrequent access OBS buckets are supported, which correspond to obs-standard and obs-standard-ia, respectively.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Run the following commands to configure the pvc-obs-auto-example.yaml file, which is used to create a PVC.
    touch pvc-obs-auto-example.yaml
    vi pvc-obs-auto-example.yaml
    Example YAML:
    apiVersion: v1
    kind: PersistentVolumeClaim
      annotations:
        volume.beta.kubernetes.io/storage-class: obs-standard  # OBS bucket type. The value can be obs-standard (standard) or obs-standard-ia (infrequent access).
      name: pvc-obs-auto-example  # PVC name
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 1Gi   # Storage capacity in the unit of Gi. For OBS buckets, this parameter is used only for verification (fixed to 1, cannot be empty or 0). Any value you set does not take effect for OBS buckets.
    Table 1 Key parameters
    Bucket type. Currently, obs-standard and obs-standard-ia are supported.
    name
    Name of the PVC to be created.
    accessModes
    Only ReadWriteMany is supported. ReadWriteOnce is not supported.
    storage
    Storage capacity in the unit of Gi. For OBS buckets, this field is used only for verification (cannot be empty or 0). Its value is fixed at 1, and any value you set does not take effect for OBS buckets.
  3. Run the following command to create a PVC:
    kubectl create -f pvc-obs-auto-example.yaml
    After the command is executed, an OBS bucket is created in the VPC to which the cluster belongs. You can click the bucket name in Storage > OBS to view the bucket or view it on the OBS console.
