Updated on 2026-05-26 GMT+08:00
(kubectl) Creating a Pod Mounted with an EVS Volume
After an EVS volume is created or imported to CCE, you can mount it to a workload.
EVS volumes cannot be mounted across AZs. Before mounting a volume, you can run the kubectl get pvc command to obtain the available PVCs in the AZ where the current cluster is located.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following commands to configure the evs-deployment-example.yaml file, which is used to create a Deployment.
    touch evs-deployment-example.yaml
    vi evs-deployment-example.yaml
    Example of mounting an EVS volume to a Deployment (PVC-based, shared volume):
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: evs-deployment-example
      template:
          labels:
          containers:
          - image: nginx
            volumeMounts:
            - mountPath: /tmp
          imagePullSecrets:
            - name: default-secret
          restartPolicy: Always
          volumes:
          - name: pvc-evs-example
            persistentVolumeClaim:
              claimName: pvc-evs-auto-example
    Table 1 Key parameters
    Parent Parameter
    spec.template.spec.containers.volumeMounts
    name
    Name of the volume mounted to the container.
    mountPath
    Mount path of the container. In this example, the volume is mounted to the /tmp directory.
    spec.template.spec.volumes
    name
    Name of the volume.
    spec.template.spec.volumes.persistentVolumeClaim
    claimName
    Name of an existing PVC.
    spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
    Mounting an EVS volume to a StatefulSet (PVC template-based, non-shared volume):
    Example YAML:
    apiVersion: apps/v1
    kind: StatefulSet
      replicas: 1
      selector:
        matchLabels:
          app: deploy-evs-sata-in
      template:
          labels:
            failure-domain.beta.kubernetes.io/region: ap-southeast-1
            failure-domain.beta.kubernetes.io/zone: ap-southeast-1a
          containers:
            - name: container-0
              image: 'nginx:1.12-alpine-perl'
              volumeMounts:
                - name: bs-sas-mountoptionpvc
                  mountPath: /tmp
          imagePullSecrets:
      volumeClaimTemplates:
        - metadata:
            annotations:
              volume.beta.kubernetes.io/storage-class: sas
              volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxivol
            accessModes:
              - ReadWriteOnce
            resources:
              requests:
                storage: 10Gi
      serviceName: wwww
    Table 2 Key parameters
    Parent Parameter
    metadata
    name
    Name of the created workload.
    Image of the workload.
    mountPath
    spec
    serviceName
    Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
    spec.template.spec.containers.volumeMounts.name and spec.volumeClaimTemplates.metadata.name must be consistent because they have a mapping relationship.
  3. Run the following command to create the pod:
    kubectl create -f evs-deployment-example.yaml
    After the creation is complete, log in to the CCE console. In the navigation pane, choose Resource Management > Storage > EVS. Then, click the PVC name. On the PVC details page, you can view the binding relationship between the EVS volume and the PVC.
