Updated on 2026-06-16 GMT+08:00
(kubectl) Creating a PV from an Existing EVS Disk
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Log in to the EVS console, create an EVS disk, and record the volume ID, capacity, and disk type of the EVS disk.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create two YAML files for creating the PersistentVolume (PV) and PersistentVolumeClaim (PVC). Assume that the file names are pv-evs-example.yaml and pvc-evs-example.yaml.
    touch pv-evs-example.yaml pvc-evs-example.yaml
    Kubernetes Cluster Version
    YAML Example
    1.11.7 ≤ K8s version ≤ 1.13
    Clusters from v1.11.7 to v1.13
    Example YAML
    1.11 ≤ K8s version < 1.11.7
    Clusters from v1.11 to v1.11.7
    Example YAML
    K8s version = 1.9
    Clusters of v1.9
    Example YAML
    • Example YAML file for the PV:
      apiVersion: v1
      kind: PersistentVolume
        labels:
          failure-domain.beta.kubernetes.io/region: ap-southeast-1
          failure-domain.beta.kubernetes.io/zone:  ap-southeast-1a
        annotations:
          pv.kubernetes.io/provisioned-by: flexvolume-huawei.com/fuxivol
        accessModes:
        - ReadWriteOnce
        capacity:
          storage: 10Gi
        claimRef:
          apiVersion: v1
          kind: PersistentVolumeClaim
          namespace: default
        flexVolume:
          driver: huawei.com/fuxivol
          fsType: ext4
          options:
            disk-mode: SCSI
            fsType: ext4
            volumeID: 0992dbda-6340-470e-a74e-4f0db288ed82
        persistentVolumeReclaimPolicy: Delete
        storageClassName: sas
      Table 1 Key parameters
      Region where the cluster is located.
      AZ where the EVS volume is created. It must be the same as the AZ planned for the workload.
      storage
      EVS volume capacity in the unit of Gi.
      storageClassName
      EVS disk type. Supported values: High I/O (SAS) and Ultra-high I/O (SSD)
      driver
      Storage driver.
      For EVS disks, set this parameter to huawei.com/fuxivol.
      volumeID
      Volume ID of the EVS disk.
      To obtain the volume ID, log in to the CCE console, choose Resource Management > Storage, click the PVC name in the EVS tab page, and copy the PVC ID on the PVC details page.
      disk-mode
      Device type of the EVS disk. The value is VBD or SCSI.
      For CCE clusters earlier than v1.11.7, you do not need to set this field. The value defaults to VBD.
      This field is mandatory for CCE clusters from v1.11.7 to v1.13 that use Linux x86. As the EVS volumes dynamically provisioned by a PVC are created from SCSI EVS disks, you are advised to choose SCSI when manually creating volumes (static PVs). Volumes in the VBD mode can still be used after cluster upgrades.
      spec.claimRef.apiVersion
      The value is fixed at v1.
      spec.claimRef.kind
      The value is fixed at PersistentVolumeClaim.
      spec.claimRef.name
      PVC name. The value is the same as the name of the PVC created in the next step.
      spec.claimRef.namespace
      Namespace of the PVC. The value is the same as the namespace of the PVC created in the next step.
    • Example YAML file for the PVC:
      apiVersion: v1
        annotations:
          volume.beta.kubernetes.io/storage-class: sas
          volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxivol
        labels:
        namespace: default
        accessModes:
        - ReadWriteOnce
        resources:
          requests:
            storage: 10Gi
        volumeName: pv-evs-example
      Table 2 Key parameters
      Storage class, which must be the same as that of the existing PV.
      The field must be set to flexvolume-huawei.com/fuxivol.
      storage
      Requested capacity in the PVC, in Gi.
      The value must be the same as the storage size of the existing PV.
      volumeName
      Name of the PV.
      apiVersion: v1
        labels:
        accessModes:
        - ReadWriteOnce
        capacity:
          storage: 10Gi
        flexVolume:
          fsType: ext4
          options:
            fsType: ext4
      Table 3 Key parameters
      storage
      storageClassName
      driver
      Storage driver.
      volumeID
      disk-mode
      For CCE clusters earlier than v1.11.7, you do not need to set this field. The default value is VBD.
      apiVersion: v1
        annotations:
        labels:
        namespace: default
        accessModes:
        - ReadWriteOnce
        resources:
          requests:
            storage: 10Gi
      Table 4 Key parameters
      Storage class. The value can be sas or ssd. The value must be the same as that of the existing PV.
      storage
      volumeName
      Name of the PV.
    Clusters of v1.9
      apiVersion: v1
        labels:
        namespace: default
        accessModes:
        - ReadWriteOnce
        capacity:
          storage: 10Gi
        flexVolume:
          fsType: ext4
          options:
            fsType: ext4
            kubernetes.io/namespace: default
      Table 5 Key parameters
      storage
      storageClassName
      driver
      Storage driver.
      volumeID
      disk-mode
      apiVersion: v1
        annotations:
        labels:
        namespace: default
        accessModes:
        - ReadWriteOnce
        resources:
          requests:
            storage: 10Gi
        volumeNamespace: default
      Table 6 Key parameters
      storage
      volumeName
      Name of the PV.
  4. Create a PV.
    kubectl create -f pv-evs-example.yaml
  5. Create a PVC.
    kubectl create -f pvc-evs-example.yaml
    After the operation is successful, choose Resource Management > Storage to view the created PVC. You can also view the EVS disk by name on the EVS console.
  6. (Optional) Add the metadata associated with the cluster to ensure that the EVS disk associated with the mounted static PV is not deleted when the node or cluster is deleted.
    If you skip this step in this example or when creating a static PV or PVC, ensure that the EVS disk associated with the static PV has been unbound from the node before you delete the node.
    1. Obtain the tenant token. For details, see Obtaining a User Token.
    2. Obtain the EVS access address EVS_ENDPOINT. For details, see Regions and Endpoints.
    3. Add the metadata associated with the cluster to the EVS disk backing the static PV.
      curl -X POST ${EVS_ENDPOINT}/v2/${project_id}/volumes/${volume_id}/metadata --insecure \
          -d '{"metadata":{"cluster_id": "${cluster_id}", "namespace": "${pvc_namespace}"}}' \
          -H 'Accept:application/json' -H 'Content-Type:application/json;charset=utf8' \
          -H 'X-Auth-Token:${TOKEN}'
      Table 7 Key parameters
      EVS_ENDPOINT
      EVS access address. Set this parameter to the value obtained in 6.b.
      project_id
      Project ID.
      volume_id
      ID of the associated EVS disk. Set this parameter to volume_id of the static PV to be created. You can also log in to the EVS console, click the name of the EVS disk to be imported, and obtain the ID from Summary on the disk details page, as shown in Figure 1.
      cluster_id
      ID of the cluster where the EVS PV is to be created. On the CCE console, choose Resource Management > Clusters. Click the name of the cluster to be associated. On the cluster details page, obtain the cluster ID, as shown in Figure 2.
      pvc_namespace
      Namespace where the PVC is to be bound.
      TOKEN
      User token. Set this parameter to the value obtained in 6.a.
      Figure 1 Obtaining the disk ID
      Figure 2 Obtaining the cluster ID
      For example, run the following commands:
      curl -X POST https://evs.ap-southeast-1.myhuaweicloud.com:443/v2/060576866680d5762f52c0150e726aa7/volumes/69c9619d-174c-4c41-837e-31b892604e14/metadata --insecure \
          -d '{"metadata":{"cluster_id": "71e8277e-80c7-11ea-925c-0255ac100442", "namespace": "default"}}' \
          -H 'X-Auth-Token:MIIPe******IsIm1ldG
      After the request is executed, run the following commands to check whether the EVS disk has been associated with the metadata of the cluster:
      curl -X GET ${EVS_ENDPOINT}/v2/${project_id}/volumes/${volume_id}/metadata --insecure \
      curl -X GET https://evs.ap-southeast-1.myhuaweicloud.com/v2/060576866680d5762f52c0150e726aa7/volumes/69c9619d-174c-4c41-837e-31b892604e14/metadata --insecure \
          -H 'X-Auth-Token:MIIPeAYJ***9t1c31ASaQ=='
      The command output displays the current metadata of the EVS disk.
          "metadata": {
              "namespace": "default",
              "hw:passthrough": "true"
