CCE Cluster Autoscaler
Introduction
The CCE Cluster Autoscaler add-on is built on the Autoscaler component of the community. It can automatically adjust the number of cluster nodes based on the resource needs of applications, optimizing resource utilization and performance. Autoscaler is the main controller in Kubernetes. It can automatically scale nodes in or out based on resource requirements. When there are not enough node resources to accept pods in a cluster, Autoscaler adds more nodes with additional resources for those pods. Furthermore, if the resource utilization of the added nodes is low, Autoscaler will automatically remove them. For details about how to implement node auto scaling, see Creating a Node Auto Scaling Policy.
Open-source community: https://github.com/kubernetes/autoscaler
How the Add-on Works
CCE Cluster Autoscaler controls auto scale-out and scale-in.
- Auto scale-out You can choose either of the following methods:
- If a pod cannot be scheduled due to insufficient resources of worker nodes, CCE will add more nodes to the cluster. The new nodes have the same resource quotas as those configured for the node pools that the new nodes are in. Auto scale-out will be performed when:
- Node resources are insufficient.
- No node affinity policy is set in the scheduling configurations of the pod. If the pod is configured affinity for a node, the system will not automatically add more nodes in the cluster. For details about how to configure node affinity policies, see Configuring Node Affinity Scheduling (nodeAffinity).
- When the cluster meets the node scaling policy, cluster scale-out is also triggered. For details, see Creating a Node Auto Scaling Policy.
The add-on follows the "No Less, No More" policy. For example, if three cores are required for creating a pod and the system supports four-core and eight-core nodes, Autoscaler will preferentially create a four-core node.
- Auto scale-in If a node's pre-allocated CPUs and memory remain below the scale-in threshold for a sustained period (10 minutes by default), the cluster initiates a scale-in operation, automatically deleting the underutilized node. However, a node cannot be deleted from a cluster if the following pods exist:
- Pods that do not meet specific requirements set in Pod Disruption Budgets (PodDisruptionBudget)
- Pods that cannot be scheduled to other nodes due to constraints such as affinity and anti-affinity policies
- Pods that have the cluster-autoscaler.kubernetes.io/safe-to-evict: 'false' annotation
- Pods (except those created by DaemonSets in the kube-system namespace) that exist in the kube-system namespace
- Pods that are not created by the controllers (such as Deployments, ReplicaSets, jobs, and StatefulSets)
- When a node meets the scale-in conditions, CCE Cluster Autoscaler will add the DeletionCandidateOfClusterAutoscaler taint to the node in advance to prevent pods from being scheduled to the node. After the CCE Cluster Autoscaler add-on is uninstalled, if the taint still exists on the node, manually delete it.
- To ensure system stability and efficient resource utilization, CCE Cluster Autoscaler uses a conservative policy. Nodes that are not entirely idle are drained one at a time. When these nodes host pods configured with graceful termination, the draining process can be prolonged. As a result, the overall scale-in process may take more time to complete.
Notes and Constraints
- There must be enough resources in the cluster during the add-on installation.
- This add-on supports VM nodes and does not support PM nodes or BMS nodes.
- The default node pool does not support auto scaling. For details, see Description of DefaultPool.
- Node scale-in will cause PVC/PV data loss for the local PVs associated with the node. These PVCs and PVs cannot be restored or used again. In a node scale-in, a pod that uses the local PV will be evicted from the node. A new pod will be created, but it remains in a pending state. This is because the PVC used by the pod has a node label, due to which the pod cannot be scheduled.
- When CCE Cluster Autoscaler is used, some taints or annotations may affect auto scaling. Therefore, do not use the following taints or annotations in clusters:
- ignore-taint.cluster-autoscaler.kubernetes.io: The taint works on nodes. Kubernetes-native Autoscaler supports protection against abnormal scale-outs and periodically evaluates the proportion of available nodes in the cluster. When the proportion of non-ready nodes exceeds 45%, protection will be triggered. In this case, all nodes with the ignore-taint.cluster-autoscaler.kubernetes.io taint in the cluster are filtered out from the Autoscaler template and recorded as non-ready nodes, which affects cluster scaling.
- cluster-autoscaler.kubernetes.io/enable-ds-eviction: The annotation works on pods, which determines whether DaemonSet pods can be evicted by Autoscaler. For details, see Well-Known Labels, Annotations and Taints.
- CCE Cluster Autoscaler earlier than 1.27.205, 1.28.172, 1.29.134, 1.30.100, 1.32.38, 1.33.31, and 1.31.62 does not support deployment of both Snt9 and CPU nodes in the same cluster. If both kinds of nodes run in the same cluster, Snt9 nodes will be considered as non-ready nodes. When the proportion of non-ready nodes exceeds 45% of the total, the protection system is triggered. This will affect the scaling of CPU node pools in the cluster.
Installing the Add-on
- In the navigation pane, choose Add-ons. Locate CCE Cluster Autoscaler on the right and click Install.
- On the Install Add-on page, configure the specifications as needed.
There are three types of preset specifications based on the cluster scale. You can select one as required. The system will configure the number of pods and resource quotas for the add-on based on the selected preset specifications. You can see the configurations on the console.
If your cluster is large and the preset specifications do not meet your needs, you can customize the resource specifications and estimate the number of pods in the cluster to better determine the memory usage of the add-on. The recommended memory request and limit in typical large clusters can be calculated as follows:
- Memory request = Number of pods × Size of the pod YAML files (KB)/10000 × 0.28 GiB + 1 GiB
- Memory limit = Memory request + 2 GiB
For example, if there are 20,000 pods and the YAML file size of each pod is 10 KB, the memory request would be 6.6 GiB (2 × 10 × 0.28 GiB + 1 GiB) and the memory limit would be 8.6 GiB (6.6 GiB + 2 GiB). (The calculated values may differ from the recommendations listed in Table 1. You can refer to that table or use these formulas.)
- Configure Agency Settings. This configuration is supported by the add-on of 1.28.227, 1.29.189, 1.30.155, 1.31.117, 1.32.93, 1.33.86, 1.34.22, or later. Add-ons require runtime access to other cloud services. You need to configure an add-on agency to authorize these operations. For details, see Custom Agencies for Add-ons.
- Create automatically: CCE automatically creates a default agency and uses this agency for the add-on. If there is a default agency, CCE will not create one again.
- Use existing: Select one from the drop-down list. Ensure that the created agency has been assigned the required permissions. Otherwise, the add-on functions may be unavailable.
- Configure deployment policies for the add-on pods.
- Scheduling policies do not take effect on the DaemonSet pods of the add-on.
- When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
Table 2 Configurations for add-on scheduling Parameter
Multi-AZ Deployment
- Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
- Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
- Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, the add-on pods on it may fail to be migrated.
Node Affinity
- Not configured: Node affinity is disabled for the add-on pods.
- Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
- Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
- Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
Toleration
Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
The add-on applies default toleration policies for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints on pods. The tolerance time window is 60s.
For details, see Configuring Tolerance Policies.
- After the configuration is complete, click Install.
Components
| Component | Description | Resource Type |
| Autoscaler | Auto scaling for Kubernetes clusters | Deployment |
Helpful Links
- After the add-on is installed, you can create node scaling policies to increase or decrease the number of nodes. For details, see Creating a Node Auto Scaling Policy.
- If a node pool contains multiple node flavors, there are priorities for auto scaling. For details, see Priorities for Scaling Node Pools.
Release History
| Add-on Version | Supported Cluster Version | New Feature | Community Version |
| 1.34.39 | v1.34 | Fixed some issues. | |
| 1.34.35 | v1.34 | Supported the PodLevelResources feature gate. | |
| 1.34.28 | v1.34 |
| 1.34.5 | v1.34 |
| 1.33.103 | v1.33 | Fixed some issues. | |
| 1.33.99 | v1.33 | Fixed some issues. | |
| 1.33.92 | v1.33 |
| 1.33.57 | v1.33 | Fixed some issues. | |
| 1.33.54 | v1.33 | Fixed some issues. | |
| 1.33.32 | v1.33 | Fixed some issues. | |
| 1.33.31 | v1.33 | Fixed some issues. | |
| 1.33.5 | v1.33 | Supported CCE clusters v1.33. |
| 1.32.109 | v1.32 | Fixed some issues. | |
| 1.32.106 | v1.32 | Fixed some issues. | |
| 1.32.99 | v1.32 |
| 1.32.64 | v1.32 | Fixed some issues. | |
| 1.32.61 | v1.32 | Fixed some issues. | |
| 1.32.39 | v1.32 | Fixed some issues. | |
| 1.32.38 | v1.32 | Fixed some issues. | |
| 1.32.12 | v1.32 | Fixed some issues. | |
| 1.32.5 | v1.32 | Supported CCE clusters v1.32. |
| 1.31.133 | v1.31 | Fixed some issues. | |
| 1.31.130 | v1.31 | Fixed some issues. | |
| 1.31.123 | v1.31 |
| 1.31.87 | v1.31 | Fixed some issues. | |
| 1.31.85 | v1.31 | Fixed some issues. | |
| 1.31.63 | v1.31 | Fixed some issues. | |
| 1.31.62 | v1.31 | Fixed some issues. | |
| 1.31.36 | v1.31 | Fixed some issues. | |
| 1.31.29 | v1.31 | Fixed some issues. | |
| 1.31.28 | v1.31 | Fixed some issues. | |
| 1.31.13 | v1.31 | The scale-down delay and utilization thresholds can be configured for node pools. | |
| 1.31.8 | v1.31 | Supported CCE clusters v1.31. |
| 1.30.172 | v1.30 | Fixed some issues. | |
| 1.30.167 | v1.30 | Fixed some issues. | |
| 1.30.161 | v1.30 |
| 1.30.125 | v1.30 | Fixed some issues. | |
| 1.30.123 | v1.30 | Fixed some issues. | |
| 1.30.101 | v1.30 | Fixed some issues. | |
| 1.30.100 | v1.30 | Fixed some issues. | |
| 1.30.74 | v1.30 | Fixed some issues. | |
| 1.30.67 | v1.30 | Fixed some issues. | |
| 1.30.66 | v1.30 | Fixed some issues. | |
| 1.30.51 | v1.30 | The scale-down delay and utilization thresholds can be configured for node pools. | |
| 1.30.46 | v1.30 | Fixed some issues. | |
| 1.30.19 | v1.30 | Fixed some issues. | |
| 1.30.18 | v1.30 | Fixed some issues. | |
| 1.30.15 | v1.30 |
| 1.29.200 | v1.29 | Fixed some issues. | |
| 1.29.196 | v1.29 | Fixed some issues. | |
| 1.29.195 | v1.29 |
| 1.29.159 | v1.29 | Fixed some issues. | |
| 1.29.157 | v1.29 | Fixed some issues. | |
| 1.29.135 | v1.29 | Fixed some issues. | |
| 1.29.134 | v1.29 | Fixed some issues. | |
| 1.29.108 | v1.29 | Fixed some issues. | |
| 1.29.101 | v1.29 | Fixed some issues. | |
| 1.29.100 | v1.29 | Fixed some issues. | |
| 1.29.84 | v1.29 | The scale-down delay and utilization thresholds can be configured for node pools. | |
| 1.29.79 | v1.29 | Fixed some issues. | |
| 1.29.54 | v1.29 | Fixed some issues. | |
| 1.29.53 | v1.29 | Fixed some issues. | |
| 1.29.50 | v1.29 | Added the name of the target node pool to the events. | |
| 1.29.17 | v1.29 | Optimized events. | |
| 1.29.13 | v1.29 | Supported clusters v1.29. |
| 1.28.234 | v1.28 | Fixed some issues. | |
| 1.28.233 | v1.28 |
| 1.28.197 | v1.28 | Fixed some issues. | |
| 1.28.195 | v1.28 | Fixed some issues. | |
| 1.28.173 | v1.28 | Fixed some issues. | |
| 1.28.172 | v1.28 | Fixed some issues. | |
| 1.28.146 | v1.28 | Fixed some issues. | |
| 1.28.139 | v1.28 | Fixed some issues. | |
| 1.28.138 | v1.28 | Fixed some issues. | |
| 1.28.123 | v1.28 | The scale-down delay and utilization thresholds can be configured for node pools. | |
| 1.28.118 | v1.28 | Fixed some issues. | |
| 1.28.93 | v1.28 | Fixed some issues. | |
| 1.28.92 | v1.28 | Fixed some issues. | |
| 1.28.91 | v1.28 | Fixed some issues. | |
| 1.28.88 | v1.28 | Added the name of the target node pool to the events. | |
| 1.28.55 | v1.28 | Optimized events. | |
| 1.28.51 | v1.28 | Optimized the logic for generating alarms when resources in a node pool are sold out. | |
| 1.28.22 | v1.28 | Fixed some issues. | |
| 1.28.20 | v1.28 | Fixed some issues. | |
| 1.28.17 | v1.28 | Fixed the issue where scale-in cannot be performed when there are custom pod controllers in a cluster. |
| 1.27.206 | v1.27 | Fixed some issues. | |
| 1.27.205 | v1.27 | Fixed some issues. | |
| 1.27.182 | v1.27 | Fixed some issues. | |
| 1.27.173 | v1.27 | Fixed some issues. | |
| 1.27.171 | v1.27 | Fixed some issues. | |
| 1.27.155 | v1.27 | The scale-down delay and utilization thresholds can be configured for node pools. | |
| 1.27.149 | v1.27 | Fixed some issues. | |
| 1.27.124 | v1.27 | Fixed some issues. | |
| 1.27.123 | v1.27 | Fixed some issues. | |
| 1.27.122 | v1.27 | Fixed some issues. | |
| 1.27.119 | v1.27 | Added the name of the target node pool to the events. | |
| 1.27.88 | v1.27 | Optimized events. | |
| 1.27.84 | v1.27 | Optimized the logic for generating alarms when resources in a node pool are sold out. | |
| 1.27.55 | v1.27 | Fixed some issues. | |
| 1.27.53 | v1.27 | Fixed some issues. | |
| 1.27.51 | v1.27 | Fixed some issues. | |
| 1.27.14 | v1.27 | Fixed the scale-in failure of nodes of different specifications in the same node pool and unexpected PreferNoSchedule taint issues. |
| 1.25.200 | v1.25 | Fixed some issues. | |
| 1.25.184 | v1.25 | The scale-down delay and utilization thresholds can be configured for node pools. | |
| 1.25.179 | v1.25 | Fixed some issues. | |
| 1.25.154 | v1.25 | Fixed some issues. | |
| 1.25.153 | v1.25 | Fixed some issues. | |
| 1.25.152 | v1.25 | Added the name of the target node pool to the events. | |
| 1.25.120 | v1.25 | Optimized events. | |
| 1.25.116 | v1.25 | Optimized the logic for generating alarms when resources in a node pool are sold out. | |
| 1.25.88 | v1.25 | Fixed some issues. | |
| 1.25.86 | v1.25 | Fixed some issues. | |
| 1.25.84 | v1.25 | Fixed some issues. | |
| 1.25.46 | v1.25 | Fixed the scale-in failure of nodes of different specifications in the same node pool and unexpected PreferNoSchedule taint issues. | |
| 1.25.34 | v1.25 |
| 1.25.21 | v1.25 |
| 1.25.11 | v1.25 |
| 1.25.7 | v1.25 |
| 1.23.159 | v1.23 | Fixed some issues. | |
| 1.23.157 | v1.23 | Fixed some issues. | |
| 1.23.156 | v1.23 | Added the name of the target node pool to the events. | |
| 1.23.125 | v1.23 | Optimized events. | |
| 1.23.121 | v1.23 | Optimized the logic for generating alarms when resources in a node pool are sold out. | |
| 1.23.95 | v1.23 | Fixed some issues. | |
| 1.23.93 | v1.23 | Fixed some issues. | |
| 1.23.91 | v1.23 | Fixed some issues. | |
| 1.23.54 | v1.23 | Fixed the scale-in failure of nodes of different specifications in the same node pool and unexpected PreferNoSchedule taint issues. | |
| 1.23.44 | v1.23 |
| 1.23.31 | v1.23 |
| 1.23.21 | v1.23 |
| 1.23.17 | v1.23 |
| 1.23.10 | v1.23 |
| 1.23.9 | v1.23 | Added the nodenetworkconfigs.crd.yangtse.cni resource object permission. | |
| 1.23.8 | v1.23 | Fixed the issue where scale-out fails when the number of nodes to be added at a time exceeds the upper limit in periodic scale-outs. | |
| 1.23.7 | v1.23 | None | |
| 1.23.3 | v1.23 | Supported CCE clusters v1.23. |
| 1.21.114 | v1.21 | Optimized the logic for generating alarms when resources in a node pool are sold out. | |
| 1.21.89 | v1.21 | Fixed some issues. | |
| 1.21.87 | v1.21 | Fixed some issues. | |
| 1.21.86 | v1.21 | Fixed the issue where the node pool auto scaling cannot meet the expected behavior after AZ topology constraints are configured for nodes. | |
| 1.21.51 | v1.21 | Fixed the scale-in failure of nodes of different specifications in the same node pool and unexpected PreferNoSchedule taint issues. | |
| 1.21.43 | v1.21 |
| 1.21.29 | v1.21 |
| 1.21.20 | v1.21 |
| 1.21.16 | v1.21 |
| 1.21.9 | v1.21 |
| 1.21.8 | v1.21 | Added the nodenetworkconfigs.crd.yangtse.cni resource object permission. | |
| 1.21.6 | v1.21 | Fixed the issue where authentication fails due to incorrect signature in the add-on request retries. | |
| 1.21.4 | v1.21 | Fixed the issue where authentication fails due to incorrect signature in the add-on request retries. | |
| 1.21.2 | v1.21 | Fixed the issue where auto scaling may be blocked due to a failure in deleting an unregistered node. | |
| 1.21.1 | v1.21 | Fixed the issue where the node pool modification in the existing periodic auto scaling rule does not take effect. |
| 1.19.76 | v1.19 |
| 1.19.56 | v1.19 | Fixed the scale-in failure of nodes of different specifications in the same node pool and unexpected PreferNoSchedule taint issues. | |
| 1.19.48 | v1.19 |
| 1.19.35 | v1.19 |
| 1.19.27 | v1.19 |
| 1.19.22 | v1.19 |
| 1.19.14 | v1.19 |
| 1.19.13 | v1.19 | Fixed the issue where scale-out fails when the number of nodes to be added at a time exceeds the upper limit in periodic scale-outs. | |
| 1.19.12 | v1.19 | Fixed the issue where authentication fails due to incorrect signature in the add-on request retries. | |
| 1.19.11 | v1.19 | Fixed the issue where authentication fails due to incorrect signature in the add-on request retries. | |
| 1.19.9 | v1.19 | Fixed the issue where auto scaling may be blocked due to a failure in deleting an unregistered node. | |
| 1.19.8 | v1.19 | Fixed the issue where the node pool modification in the existing periodic auto scaling rule does not take effect. | |
| 1.19.7 | v1.19 | Regular upgrade of add-on dependencies | |
| 1.19.6 | v1.19 | Fixed the issue where repeated scale-out is triggered when taints are asynchronously updated. | |
| 1.19.3 | v1.19 | Supported scheduled scaling policies based on the total number of nodes, CPU limit, and memory limit; and fixed other functional defects. |
| 1.17.27 | v1.17 |
| 1.17.22 | v1.17 | Optimized logging. | |
| 1.17.21 | v1.17 | Fixed the issue where scale-out fails when the number of nodes to be added at a time exceeds the upper limit in periodic scale-outs. | |
| 1.17.19 | v1.17 | Fixed the issue where authentication fails due to incorrect signature in the add-on request retries. | |
| 1.17.17 | v1.17 | Fixed the issue where auto scaling may be blocked due to a failure in deleting an unregistered node. | |
| 1.17.16 | v1.17 | Fixed the issue where the node pool modification in the existing periodic auto scaling rule does not take effect. | |
| 1.17.15 | v1.17 | Unified resource specification configuration unit. | |
| 1.17.14 | v1.17 | Fixed the issue where repeated scale-out is triggered when taints are asynchronously updated. | |
| 1.17.8 | v1.17 | Fixed bugs. | |
| 1.17.7 | v1.17 | Added log content and fixed bugs. | |
| 1.17.5 | v1.17 | Supported clusters v1.17 and allowed scaling events to be displayed on the CCE console. | |
| 1.17.2 | v1.17 | Supported clusters v1.17. |
