Creating a Secret
A secret is a Kubernetes resource used to store sensitive information, such as authentication credentials and keys required by workloads. The content of a secret is defined by users. After a secret is created, containerized workloads can securely use it through volume mounts or environment variable injection.
Secrets decouple sensitive data from container images, preventing sensitive data from being exposed in plaintext within images or configuration files. This significantly reduces the risk of data leakage and improves the security and portability of workloads.
Notes and Constraints
Secrets cannot be used in static pods.
You can use either of the following ways.
- Choose ConfigMaps and Secrets in the navigation pane, click the Secrets tab, and click Create Secret in the upper right corner.
- Configure parameters.
Table 1 Parameters for creating a secret Parameter
Name
Name of the secret you create, which must be unique.
Namespace
Namespace to which the secret belongs. If you do not specify this parameter, the value default is used by default.
Description of a secret.
Secret Type
Type of the secret you create.
- Opaque: common secret.
- kubernetes.io/dockerconfigjson: a secret that stores the authentication information required for pulling images from a private repository.
- kubernetes.io/tls: Kubernetes TLS secret, which is used to store the certificate required by Layer 7 load balancing Services. For details about examples of the kubernetes.io/tls secret and its description, see TLS secrets.
- IngressTLS: TLS secret provided by CCE to store the certificate required by Layer 7 load balancing Services.
- Other: another type of secret, which is specified manually.
Data
Workload secret data can be used in containers.
- If Secret Type is set to Opaque, click Add. In the window that slides out from the right, enter a key-value pair and select Auto Base64 Encoding.
Key: Enter 1 to 63 characters. Only digits, letters, periods (.), hyphens (-), and underscores (_) are allowed. The key cannot start with two periods (..).
- If Secret Type is set to kubernetes.io/dockerconfigjson, click Add and enter the account and password for logging in to the private image repository.
- If Secret Type is set to kubernetes.io/tls or IngressTLS, upload the certificate file and private key file. NOTE:
- A certificate is a self-signed or CA-signed credential used for identity authentication.
- A certificate request is a request for a signature with a private key.
Tag Management (Optional)
Labels of the secret. Click Add Label and enter key-value pairs. The key and value must contain 1 to 63 characters that start and end with a letter or digit. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
- Click OK.
The new secret is displayed in the key list.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Encode the secret value using Base64.
# echo -n "content-to-be-encoded" | base64 ******
- Create a file named cce-secret.yaml and edit it.
vi cce-secret.yaml
The following YAML file uses the Opaque type as an example. For details about other types, see Secret Resource File Configuration Example.
apiVersion: v1 kind: Secret metadata: name: mysecret type: Opaque data: <your_key>: <your_value> # Enter a key-value pair. The value must be encoded using Base64.
- Create the secret.
kubectl create -f cce-secret.yaml
You can query the secret after creation.
kubectl get secret -n default
This section provides configuration examples for secret files.
- Opaque type
The secret.yaml file is defined as shown below. The data field is filled in as a key-value pair, and the value field must be encoded using Base64. For details, see Base64 Encoding.
apiVersion: v1 kind: Secret metadata: name: mysecret #Secret name namespace: default #Namespace. The default value is default. data: <your_key>: <your_value> # Enter a key-value pair. The value must be encoded using Base64. type: Opaque
- kubernetes.io/dockerconfigjson type
The secret.yaml file is defined as shown below. The value of .dockerconfigjson must be encoded using Base64. For details, see Base64 Encoding.
apiVersion: v1 kind: Secret metadata: name: mysecret #Secret name namespace: default #Namespace. The default value is default. data: .dockerconfigjson: eyJh***** # Content encoded using Base64. type: kubernetes.io/dockerconfigjson
To obtain the .dockerconfigjson content, take the following steps:
- Obtain the following login information of the image repository:
- Image repository address: The section uses address as an example. Replace it with the actual address.
- Username: The section uses username as an example. Replace it with the actual username.
- Password: The section uses password as an example. Replace it with the actual password.
- Use Base64 to encode the key-value pair username:password and fill the encoded content in 3.
echo -n "username:password" | base64Command output:
dXNlcm5hbWU6cGFzc3dvcmQ=
- Use Base64 to encode the following JSON content:
echo -n '{"auths":{"address":{"username":"username","password":"password","auth":"dXNlcm5hbWU6cGFzc3dvcmQ="}}}' | base64Command output:
eyJhdXRocyI6eyJhZGRyZXNzIjp7InVzZXJuYW1lIjoidXNlcm5hbWUiLCJwYXNzd29yZCI6InBhc3N3b3JkIiwiYXV0aCI6ImRYTmxjbTVoYldVNmNHRnpjM2R2Y21RPSJ9fX0=
The encoded content is the .dockerconfigjson content.
- kubernetes.io/tls type The value of tls.crt and tls.key must be encoded using Base64. For details, see Base64 Encoding.
kind: Secret apiVersion: v1 metadata: name: mysecret #Secret name namespace: default #Namespace. The default value is default. data: tls.crt: LS0tLS1CRU*****FURS0tLS0t # Certificate content, which must be encoded using Base64. tls.key: LS0tLS1CRU*****VZLS0tLS0= # Private key content, which must be encoded using Base64. type: kubernetes.io/tls
- IngressTLS type The value of tls.crt and tls.key must be encoded using Base64. For details, see Base64 Encoding.
kind: Secret apiVersion: v1 metadata: name: mysecret #Secret name namespace: default #Namespace. The default value is default. data: tls.crt: LS0tLS1CRU*****FURS0tLS0t # Certificate content, which must be encoded using Base64. tls.key: LS0tLS1CRU*****VZLS0tLS0= # Private key content, which must be encoded using Base64. type: IngressTLS
Base64 Encoding
To perform Base64 encoding on a string, run the following command:
echo -n "Content to be encoded" | base64 Related Operations
The secret list contains system secret resources that can be queried only. The system secret resources cannot be updated or deleted.
| Operation | Description |
| Editing a secret's YAML file | Click Edit YAML in the row where the target secret resides to edit its YAML file. |
| Updating a secret |
| Deleting a secret | Select the secret to be deleted and choose More > Delete. Follow the prompts to delete the secret. |
| Deleting secrets in batches |
