Accessing a Cluster Using kubectl
- Private access: Clients access the cluster's API server via an intranet IP address, keeping data traffic internal and enhancing security.
- Public access: The cluster's API server exposes a public API, allowing clients to access the Kubernetes cluster over the Internet. When using the Internet for access, you can choose whether to enable two-way domain name trust.
- If two-way domain name trust is disabled, kubectl and the API server use one-way certificate authentication, which is less secure. In this mode, only kubectl verifies the API server's certificate, while the API server does not verify kubectl's certificate.
- If two-way domain name trust is enabled, kubectl and the API server use mutual certificate authentication, which is more secure. In this mode, kubectl verifies the API server's certificate, and the API server verifies kubectl's certificate (specified in the client-certificate-data field in the kubeconfig file). For more details, see Two-Way Domain Name Trust.
This section uses a CCE standard cluster as an example to describe how to access a CCE cluster using kubectl.
How It Works
kubectl retrieves cluster information from a kubeconfig file and communicates with the Kubernetes API server. The kubeconfig file is the credential for kubectl to access a Kubernetes cluster. It contains the cluster connection information (such as the API server address and CA certificate), user authentication credentials (such as the client certificate and token), and context (cluster, user, and default namespace). With these details, kubectl can interact with the Kubernetes cluster to perform management tasks.
- A client that can access the Internet is available.
- If private access is used, the client and the cluster to be accessed must be in the same VPC.
- If public access is used, the cluster to be accessed has an EIP bound. For details about how to bind an EIP, see Procedure.
In a cluster with an EIP bound, kube-apiserver will be exposed to the Internet and may be attacked. To resolve this issue, you can configure Advanced Anti-DDoS for the EIP of the node on which kube-apiserver runs or configure security group rules.
Notes and Constraints
A kubeconfig file contains user authentication credentials. When you use this file to access a cluster, kubectl accesses the cluster based on the credentials and permissions specified in the file.
For details about user permissions, see Relationship Between IAM Role/Policy Permissions and Namespace Permissions.
Billing
An EIP must be bound to the target cluster for public access. In this case, you will be billed for the EIP. For details, see EIP Price Calculator.
Step 1: Download kubectl
Before using kubectl to access a cluster, install kubectl on the client. Run the kubectl version command to check whether kubectl is installed. If it is installed, skip this step. This section uses Linux as an example to describe how to install and configure kubectl. For details, see Installing kubectl.
- Log in to your client and download kubectl. v1.25.0 specifies the version. Replace it as needed.
cd /home curl -LO https://dl.k8s.io/release/v1.25.0/bin/linux/amd64/kubectl - Run the following command to install kubectl:
chmod +x kubectl mv -f kubectl /usr/local/bin
- Run the following command to check whether kubectl has been installed:
kubectl version
If information similar to the following is displayed, kubectl has been installed:
Client Version: xxx Kustomize Version: xxx Server Version: xxx
Step 2: Obtain the kubectl Configuration File (kubeconfig)
Obtain kubeconfig (the kubectl configuration file) from the cluster for access.
- On the Overview page of the cluster console, locate the Connection Information area and click Configure next to kubectl. Figure 2 Connection information
- On the slide-out panel, locate the Download the kubeconfig file area, select Private access or Public access for Current data, and copy the configuration file. Figure 3 Downloading the configuration file
- kubeconfig is used for cluster authentication. If the file is leaked, your cluster may be attacked.
- The Kubernetes permissions assigned by the configuration file downloaded by IAM users are the same as those assigned to the IAM users on the CCE console.
- In Linux, if the KUBECONFIG environment variable is set, kubectl will load it instead of $home/.kube/config.
- An issued kubeconfig certificate remains valid even if the user who requested it is deleted. To ensure cluster security, manually revoke the user's cluster access credentials. For details, see Revoking a Cluster Access Credential.
Step 3: Configure kubectl
The kubeconfig file is stored on the client, and kubectl uses it to access and interact with the cluster.
- Log in to your client.
- Create the kubeconfig.yaml file. You can change the file name as needed. The file is used to store the configuration file information obtained in 3.
vim kubeconfig.yamlCopy the configuration file information obtained in 3 to kubeconfig.yaml and save the file.
- Save the kubeconfig.yaml file to $HOME/.kube/config. kubectl will automatically read from it. If you save the kubeconfig.yaml file in a different path, set the KUBECONFIG environment variable to point to that path.
To persist the environment variable, add export KUBECONFIG="<your-path>" to your shell configuration file (for example, ~/.bashrc), and run source ~/.bashrc to apply the changes.
cd /home mkdir -p $HOME/.kube mv -f ~/kubeconfig.yaml $HOME/.kube/config # Change kubeconfig.yaml to the file name. - Switch the kubectl access mode based on service scenarios.
- If private access is used through a VPC, run the following command:
kubectl config use-context internal
- If public access is enabled and two-way domain name trust is not required, ensure that an EIP is bound to the cluster. Then, run the following command:
kubectl config use-context external
- If public access is enabled and two-way domain name trust is required, ensure that an EIP is bound to the cluster. Then, run the following command:
kubectl config use-context externalTLSVerify
- Run the following command on the client to check whether the client can access the cluster using kubectl:
kubectl cluster-info # Check the cluster information.
If the following information is displayed, the client can access the cluster using kubectl:
Kubernetes control plane is running at https://xx.xx.xx.xx:5443 CoreDNS is running at https://xx.xx.xx.xx:5443/api/v1/namespaces/kube-system/services/coredns:dns/proxy To further debug and diagnose cluster problems, use 'kubectl cluster-info dump'.
Two-way domain name trust is a mutual authentication mechanism that verifies the identities of both the client and server. This mode enhances security between clusters and clients, preventing unauthorized access.
- After an EIP is bound to an API server, two-way domain name trust is disabled by default if kubectl is used to access the cluster. You can run kubectl config use-context externalTLSVerify to enable the two-way domain name trust.
- When an EIP is bound to or unbound from a cluster, or a custom domain name is configured or updated, the cluster access address (including the EIP bound to the cluster and all custom domain names configured for the cluster) will be added to the cluster server certificate.
- Asynchronous cluster synchronization takes about 5 to 10 minutes. You can view the synchronization result in Synchronize Certificate in Operation Records.
- For a cluster that has an EIP bound, if the authentication fails (x509: certificate is valid) when two-way domain name trust is used, bind the EIP again and download kubeconfig.yaml again.
- If the two-way domain name trust is not supported, kubeconfig.yaml contains the "insecure-skip-tls-verify": true field, as shown in Figure 4. To use two-way domain name trust, download the kubeconfig.yaml file again and enable two-way domain name trust.
Common Issues
- Error from server Forbidden
When you use kubectl to create or query Kubernetes resources, the following output is returned:
# kubectl get deploy Error from server (Forbidden): deployments.apps is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "deployments" in API group "apps" in the namespace "default"
The cause is that the user does not have the permissions to operate the Kubernetes resources. For details about how to assign permissions, see Configuring Namespace Permissions (Kubernetes RBAC-based).
- The connection to the server localhost:8080 was refused
The connection to the server localhost:8080 was refused - did you specify the right host or port?
The cause is that cluster authentication is not configured for the kubectl client. For details, see Step 2: Obtain the kubectl Configuration File (kubeconfig).
- use of X25519 is not allowed in FIPS 140-only mode When you run kubectl, the following information is displayed:
failed to download openapi: Get "https://x.x.x.x:5443/openapi/v2?timeout=32s": crypto/ecdh: use of X25519 is not allowed in FIPS 140-only mode; if you choose to ignore these errors, turn validation off with --validate=false
Perform the following steps to resolve this issue:
- Add --validate=false to kubectl apply -f to skip the verification.
- Download the latest version of kubectl. For details, see Accessing a Cluster Using kubectl.
Helpful Links
- Connect to multiple clusters using kubectl.
- Configure kubeconfig for fine-grained management on cluster resources.
- For details about how to manually revoke a cluster access credential, see Revoking a Cluster Access Credential.
