- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
On this page
Show all
Help Center/
Cloud Container Engine_Autopilot/
User Guide/
Storage/
EVS Volumes/
Expanding the Capacity of an EVS Volume
If the EVS volume mounted to a workload does not have enough space, you can increase its capacity by expanding it. This section describes how to expand the capacity of an EVS volume through the console.
You have created a cluster of v1.27.8-r0, v1.28.6-r0, or later.
- In the navigation pane on the left, choose Storage. Then click the PVCs tab. Locate the target PVC and click More > Scale-out in the Operation column.
Figure 1 Expanding the capacity of an EVS volume
- Enter the capacity to be added and click OK. In this example, 10 GiB is added.
The capacity can only be increased.
Figure 2 Configuring the capacity to be expanded - Verify that the expansion is successful. On the PVCs tab, you can see that the PVC capacity is expanded from 10 GiB to 20 GiB.
Parent Topic: EVS Volumes
