- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
EVS Volume Overview
For persistent storage, CCE Autopilot allows you to mount the storage volumes (PVs) created from Elastic Volume Service (EVS) disks to a path of a container. When the container is migrated within an AZ, the mounted volumes are also migrated. By using EVS volumes, you can mount the remote file directory of a storage system to a container so that data in the data volume is permanently preserved. Even if the container is deleted, the data in the data volume is still stored in the storage system.
View the regions where EVS volumes are supported on the console. You can also view Function Overview to learn about all regions where EVS volumes are supported.
EVS Disk Specifications
EVS performance metrics include:
- IOPS: the number of input/output operations performed by an EVS disk per second
- Throughput: the amount of data read from and written into an EVS disk per second
- I/O latency: the minimum interval between two consecutive I/O operations on an EVS disk
Item |
Extreme SSD |
General Purpose SSD |
Ultra-high I/O |
High I/O |
Max. capacity (GiB) |
Max. IOPS |
128000 |
20000 |
50000 |
5000 |
Max. throughput (MiB/s) |
1000 |
250 |
350 |
150 |
Burst IOPS limit |
64000 |
8000 |
16000 |
5000 |
Disk IOPS |
Min. (128,000, 1,800 + 50 x Capacity) |
Min. (20,000, 1,800 + 12 x Capacity) |
Min. (50,000, 1,800 + 50 x Capacity) |
Min. (5,000, 1,800 + 8 x Capacity) |
Disk throughput (MiB/s) |
Min. (1,000, 120 + 0.5 x Capacity) |
Min. (250, 100 + 0.5 x Capacity) |
Min. (350, 120 + 0.5 x Capacity) |
Min. (150, 100 + 0.15 x Capacity) |
Single-queue access latency (ms) |
Sub-millisecond |
1 |
1 |
1~ 3 |
API name |
ESSD |
GPSSD |
SSD |
SAS |
For details about EVS disks, see Disk Types and Performance.
EVS volumes can be mounted in the following modes based on application scenarios:
- Using an existing EVS disk through a static PV: Use an existing EVS disk to create a PV and then mount storage to the workload through a PVC. This mode applies to scenarios where the underlying storage is available or billed on a yearly/monthly basis.
- Using an EVS disk through a dynamic PV: You do not need to create EVS volumes beforehand. Instead, specify a StorageClass when creating a PVC. Then, an EVS volume and PV will be created automatically. This mode applies to scenarios where no underlying storage is available.
- Dynamically mounting an EVS volume to a StatefulSet: Each pod is associated with a unique PVC and PV. After a pod is rescheduled, the original PV can still be mounted to it based on the PVC name. This mode applies to StatefulSets with multiple pods.
Billing
- By default, the EVS disks automatically created when you specify the StorageClass is billed on a pay-per-use basis and cannot be changed to yearly/monthly. To use a yearly/monthly-billed EVS disk, use an existing one.
- For details about the EVS disk pricing, see Billing for Disks.
