- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Setting AZ Affinity
An availability zone (AZ) is a physical region in a data center where resources use independent power supplies and networks. Nodes in the same AZ can quickly communicate with each other through a high-speed network, while nodes in different AZs need to communicate with each other across physical distances, which may cause latency and risks.
Scheduling pods to different AZs improves the availability and fault tolerance of applications.
For a CCE Autopilot cluster, you can set workload annotations to implement AZ affinity and schedule pods to specified AZs.
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Workloads in the navigation pane on the left, and click the Create Workload in the upper right corner.
- In the Advanced Settings area, select Labels and Annotations and set the following annotation:
- Key: node.cce.io/node-az-list
- Value: AZ name. Use commas (,) to separate multiple AZs.
For details about AZ names in different regions, see Regions and Endpoints.
Figure 1 Setting AZ affinity - Configure other workload parameters and click Create Workload.
