Updated on 2026-01-22 GMT+08:00
Creating an Alarm Rule
You can create alarm rules for CBR.
Hybrid cloud backup allows monitoring on vault capacity only. On-premises operations and events cannot be monitored.
Enabling One-Click Monitoring on the CBR Console Dashboard
  1. Log in to the CBR console.
  2. Click and choose Storage > Cloud Backup and Recovery. In the navigation pane, click Overview. In the Monitoring area on the dashboard, view monitoring metrics.
  3. In the Alarms area, click Create Alarm Rule. In the dialog box, view recommended alarm rules. Enable One-Click Monitoring. The enabled alarm rules will take effect for all resources in the current region.
  4. If the current recommended alarm rules cannot meet your requirements, click Create alarm rules.
Creating an Alarm Rule Using Cloud Eye
  1. Log in to the Cloud Eye console.
  2. Under Management & Governance, select Cloud Eye. In the navigation pane, choose Alarm Management > Alarm Rules.
  3. On the displayed page, click Create Alarm Rule in the upper right corner.
  4. On the displayed Create alarm rule page, configure the parameters.
    1. Set Name and Description.
      Figure 1 Configuring the alarm rule name and description
      Parameters for configuring the rule name and description
      Example Value
      Name
      Name of the alarm rule. Cloud Eye will generate a random name, but you can modify it.
      alarm-cgnw
      Alarm rule description. This parameter is optional.
    2. Configure alarm content parameters.
      Figure 2 CBR vault-based alarm rule configuration
      Figure 3 CBR event-based alarm rule configuration
    3. Configure alarm notifications.
      Figure 4 Configuring alarm notifications
      Table 1 Parameters for configuring alarm notifications
      Example Value
      Alarm Notification
      Specifies whether users are notified when alarms are triggered. Notifications can be delivered by email, text message, or HTTP/HTTPS requests.
      You can enable (recommended) or disable Alarm Notification.
      Notification Window
      Cloud Eye sends notifications only within the notification window specified in the alarm rule.
      If Notification Window is set to 00:00-8:00, Cloud Eye sends alarm notifications only within 00:00-8:00.
      Notification Object
      The name of the topic the alarm notification is to be sent to.
      If you enable alarm notification, you need to select a topic. If no desirable topics are available, create one and subscribe to it first. For more details, see the Simple Message Notification User Guide.
      Trigger Condition
      The condition for triggering the alarm notification. You can select Generated alarm, Cleared alarm, or both.
    4. Click Create.
After the alarm rule is created, if the metric data reaches the specified threshold or there is a CBR event, Cloud Eye immediately informs you that an exception has occurred. For details, see the Cloud Eye User Guide.
