Monitored Events
On Cloud Eye, you can query CBR events and alarms. You can create alarm rules to be notified when specific events happen.
Namespace
SYS.CBR
Monitored Events
| Event Name | Event ID | Severity | Description | Solution | Impact |
| Backup creation failed | backupFailed | Critical | The backup creation failed. | Manually create the backup or contact technical support. | Data may be lost. |
| Restoration from a backup failed | restorationFailed | Critical | The restoration from a backup failed. | Restore the resource from another backup or contact technical support. | Data may be lost. |
| Backup deletion failed | backupDeleteFailed | Critical | The backup deletion failed. | Try again later or contact technical support. | Billing may be abnormal. |
| Vault deletion failed | vaultDeleteFailed | Critical | The vault deletion failed. | Try again later or contact technical support. | Billing may be abnormal. |
| Replication failure | replicationFailed | Critical | The backup replication failed. | Try again later or contact technical support. | Data may be lost. |
| Backup created | backupSucceeded | Major | The backup was created. | None | None |
| Resource restored from a backup | restorationSucceeded | Major | The resource was restored successfully from a backup. | Check that data is successfully restored. | None |
| Backup deleted | backupDeletionSucceeded | Major | The backup was deleted successfully. | None | None |
| Vault deleted | vaultDeletionSucceeded | Major | The vault was deleted successfully. | None | None |
| Replication succeeded | replicationSucceeded | Major | The backup was replicated successfully. | None | None |
| Agent offline | agentOffline | Critical | The Agent is offline. | Ensure that the Agent is working properly and can connect to Huawei Cloud. | Backup tasks may fail. |
| Agent online | agentOnline | Major | The Agent is online. | None | None |
