Updated on 2025-11-18 GMT+08:00
Restoring from a Desktop Backup
You can use a desktop backup to restore the desktop to its state when the backup was created.
The desktop to be restored is Available.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. In the row of the backup, click Restore Data.
    The desktop data will be overwritten by the data captured at the time of backup. The restoration cannot be undone.
    Desktops will be shut down during restoration, so you are advised to perform a restoration during off-peak hours.
    Figure 1 Restoring a desktop
  4. (Optional) Deselect Start the desktop immediately after restoration.
    If you do so, manually start the desktop after the restoration is complete.
  5. Click Yes. You can check whether data is successfully restored on the Backups tab of Desktop Backups or on the Workspace console.
    When the status of the desktop changes to Available, the restoration is successful.
    If the restoration takes a long time, click the target backup name in the backup list. On the backup details page, check the value of Instant Restore Support. If the value is No, the current backup is not an enhanced backup. Therefore, the restoration takes a long time. You are advised to manually create a full backup for the resources. The new backup is an enhanced backup and can then be used to restore resources.
