Before enabling database server backup, you also need to install the Agent on your ECSs.
If Agent is not installed on servers, database server backup will fail, but a common server backup can be performed instead. To ensure a successful database server backup, download and install the Agent first.
Operation Instructions
- Database server backup is available only for x86-based ECSs. It is not available for Kunpeng-based ECSs.
- During the Agent installation, the system requires the rdadmin user's permissions to run the installation program. To improve O&M security, change the user rdadmin's password of the Agent OS regularly and disable this user's remote login permission. For details, see Changing the Password of User rdadmin.
- Table 1 lists the OSs that can have the Agent installed. Only Windows OSs in English can have the Agent installed.
Table 1 OSs supporting the Agent | Database | OS | Supported Versions |
| SQL Server 2008 | Windows | Windows Server 2012, 2012 R2, 2019 for x86_64 |
| SQL Server 2012 | Windows | Windows Server 2012, 2012 R2, 2019 for x86_64 |
| SQL Server 2019 | Windows | Windows Server 2019 for x86_64 |
| SQL Server 2014/2016/EE | Windows | Windows Server 2016 Datacenter for x86_64 |
| MySQL 5.5/5.6/5.7 | Red Hat | Red Hat Enterprise Linux 6 and 7 for x86_64 |
| SUSE | SUSE Linux Enterprise Server 12, 15 SP1, 15 SP2 for x86_64 |
| CentOS | CentOS 6 and 7 for x86_64 |
| EulerOS | Euler OS 2.2 and 2.3 for x86_64 |
| HANA 1.0/2.0 | SUSE | SUSE Linux Enterprise Server 12 for x86_64 |
For Windows servers, ensure that Volume Shadow Copy is running properly. Otherwise, the backup will fail.
- Table 2 lists the supported SHA-256 values.
Table 2 SHA-256 values | Package Name | SHA-256 Value |
| Cloud Server Backup Agent-CentOS6-x86_64.tar.gz | f0c59ccb4443bcb6e874bf6e3c574914f9f8b27f3f7379e2d81956a9972802f3 |
| Cloud Server Backup Agent-CentOS7-x86_64.tar.gz | 2d3028cb794e1699bae9f65746a60ae99be17d5c4c5e7ebe6b45ff261db9c3c7 |
| Cloud Server Backup Agent-EulerOS2-x86_64.tar.gz | 4fb4cf9cb6f5b0e6c13d8ad8bf928754cb95332ee645a97fd0bb3fcbeb53d003 |
| Cloud Server Backup Agent-RedHat6-x86_64.tar.gz | 6ae3838fb5644f0f47282c211fe20c6b57a7c5c1d683cd5a1f55860d259b2054 |
| Cloud Server Backup Agent-RedHat7-x86_64.tar.gz | 40fa68a808d9da04672678b2773e3345ea6c9dee3c17d598acb66a023cc5cacc |
| Cloud Server Backup Agent-SuSE11-x86_64.tar.gz | 346cc9f1fc0a41a817abb2db61e657a4d615449e13bc46f1c1cfbadc0b281f47 |
| Cloud Server Backup Agent-SuSE12-x86_64.tar.gz | 625279b9c9d17ddcc4210b78242efebacdad73f808b86754659d243ece85a400 |
| Cloud Server Backup Agent-WIN64.zip | b7b2067ac89f1fec635d82e3fe2ea794ce6482f9880838f34924b383be44ac4e |
During Agent installation, the system automatically opens one of the firewall ports between 59526 and 59528 on the ECS. If port 59526 is in use, it will try 59527 and then move to the next available port in the range.
- The username and password for logging in to the console have been obtained.
- The security group has been configured.
- The Agent Status of the ECS is Not installed.
- If you use Internet Explorer, you need to add the websites you will use to trusted sites.
Installing the Agent for a Linux OS (Method 1)
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- In the navigation pane, choose Cloud Server Backups.
- Click the Agent Installation tab.
Figure 1 Installation page for Linux
- In method 1, select the corresponding Agent version as required, and copy the installation command in step 2.
- On the ECS page, select the target server and click Remote Login in the Operation column to log in to the ECS.
Ensure that the package's SHA-256 value is the same as that listed in Table 2.
In method 2, click Download, select a version based on the target ECS OS, and click OK to obtain the software package.
- Paste the installation command in step 2 to the ECS and run the command as user root.
The system displays a message indicating that the agent is installed successfully. See
Figure 2.
Figure 2 Agent installed successfully on the Linux ECS
If the execution fails, run the yum install -y bind-utils command to install the dig module. If the installation still fails, use method 2 to install the Agent for a Linux OS.
- After the installation is complete, Agent is running properly. To implement application-consistent backup for MySQL, SAP HANA, or other types of databases, modify or compile a custom script by referring to the Cloud Backup and Recovery Best Practices.
Installing the Agent for a Linux OS (Method 2)
- Log in to the CBR console. Click
in the upper left corner and select a region. - Click the Agent Installation tab.
Figure 3 Installation page for Linux
- In method 2, click Download. On the displayed download page, select the version to be downloaded based on the OS of the target ECS, and click OK. See Figure 4.
Figure 4 Downloading the Agent
- Check that the package's SHA-256 value is the same as that listed in Table 2.
- Use a file transfer tool, such as Xftp, SecureFX, or WinSCP, to upload the Agent installation package to your ECS.
- After the upload, go to the ECS page. Select the target server and click Remote Login in the Operation column to log in to the ECS.
- Run the tar -zxvf command to decompress the Agent installation package to any directory and run the following command to go to the bin directory:
cd bin
- Run the following command to run the installation script:
sh agent_install_ebk.sh
- Check that the system displays a message indicating that the Agent is installed successfully. See Figure 5.
Figure 5 Successful Agent installation for Linux
- If the MySQL or SAP HANA database has been installed on the ECS, run the following command to encrypt the password for logging in to the MySQL or SAP HANA database:
/home/rdadmin/Agent/bin/agentcli encpwd
- Use the encrypted password in previous step to replace the database login password in the script in /home/rdadmin/Agent/bin/thirdparty/ebk_user/.
Installing the Agent for a Windows OS (Method 1)
Figure 6 Installation page for Windows
- In method 1, click Download. Save the downloaded installation package to a local directory.
- Log in to the ECS console and access the ECS as the administrator.
- Decompress the installation package to any directory and go to the Installation path\bin directory.
- Double-click the agent_install_ebk.bat script to start the installation.
- Check that the system displays a message indicating that the Agent is installed successfully. See Figure 7.
Figure 7 Successful Agent installation for Windows
Installing the Agent for a Windows OS (Method 2)
Figure 8 Installation page for Windows
- On the ECS page, select the target server and click Remote Login in the Operation column to log in to the ECS as the administrator.
- Copy the installation commands in step 2 of method 2 to the server and run the command in the Command Prompt.
- Copy the installation command in step 3 of method 2 to the browser. The following uses ap-southeast-1 as the example region. Then press Enter to download the installation package.
https://csbs-agent-ap-southeast-1.obs.ap-southeast-1.myhwclouds.com/Cloud Server Backup Agent-WIN64.zip
- Decompress the installation package to any directory. Then go to the Installation path\bin directory.
- Check that the system displays a message indicating that the Agent is installed successfully. See Figure 9.
Figure 9 Successful Agent installation for Windows
