Help Center/ Cloud Backup and Recovery/ User Guide/ Data Restoration/ Creating an Image from a Cloud Server Backup
Updated on 2026-07-09 GMT+08:00
CBR allows you to create images using ECS backups. You can use the images to provision ECSs to rapidly restore service running environments.
You can also use server backups to create images and then provision servers to restore data if your servers were accidentally deleted.
Notes
  • Images created using a backup are the same, so CBR allows you to use a backup to create only one full-ECS image that contains the whole data of the system disk and data disks of the ECS, in order to save the image quota. After an image is created, you can use the image to provision multiple ECSs in a batch.
  • A backup with an image created cannot be deleted directly. To delete such a backup, delete its image first. If a backup is automatically generated based on a backup policy and the backup has been used to create an image, the backup will not be counted as a retained backup and will not be deleted automatically.
  • A backup is compressed when it is used to create an image, so the size of the generated image may be smaller than the backup size.
Billing
  • If you use a cloud server backup to create an image, the KooGallery image and some public images are charged.
  • For more details, see Image Management Service Billing.
  • In CloudPond scenarios, cloud servers cannot be created using the images created from cloud server backups.
  • You can create an image using a backup only when the backup is in the Available state or the backup is in the Creating state and "Image can be created" is displayed under Creating.
    • Once backup creation starts, the backup enters the Creating state. After a period of time, a message stating "Image can be created" is displayed under Creating. In this case, the backup can be used for creating an image, even though it is still being created and cannot be used for restoration.
  • The backup must contain the system disk data.
  • Only ECS backups can be used to create images.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. In the row of the backup, choose More > Create Image.
  4. Create an image by referring to Creating a Full-ECS Image from a CBR Backup in the Image Management Service User Guide.
  5. Use the image to provision ECSs when needed. For details, see Creating an ECS from an Image in the Image Management Service User Guide.
Helpful Links
