Authorizing SFS Turbo
SFS Turbo provides scalable, high-performance shared file storage (NAS) for shared file access from ECSs, CCE and CCI containers, and BMSs.
Restrictions
- SFS Turbo is available in CN East-Shanghai1, CN South-Guangzhou, AP-Singapore, LA-Mexico City2, ME-Riyadh, and TR-Istanbul.
- Environments created before May 2024 do not support SFS Turbo.
- The cloud storage configuration path must be different from the log collection path.
- Log in to CAE.
- Choose Component Configurations.
- Select the target component from the drop-down list in the upper part of the page.
- Click Edit in the Cloud Storage module.
- Click Authorize SFS Turbo.
- Select an authorized SFS Turbo from the drop-down list.
To add an authorization, click Authorize SFS Turbo. For details, see Authorizing SFS Turbo.
- Configure the path to which the container is mounted and the permissions on the path. For details, see Table 1.
Table 1 Description Parameter
Mount Path
Component path to which the data storage is mounted.
NOTE:- Do not mount the data storage to a system directory, such as / or /var/run. Otherwise, an exception occurs.
- The mount path of the cloud storage must be unique.
Sub-path
Sub-path in the cloud storage referenced by data.
NOTE:- A sub-path is used to mount a local volume so that the same data volume is used in a single pod.
- If this parameter is left blank, the root path is used.
Required Permissions
Permissions on the mount path and files in the mount path. The value can be Read/Write or Read only.
- (Optional) Click Add Mount Path to configure more mount paths.
- Click OK.
You can view the configured SFS Turbo on the Cloud Storage page.
- Make the configurations take effect.
- If the component has been deployed, click Activate Settings in the upper part of the page. In the dialog box displayed on the right, confirm the configurations and click OK for the configurations to take effect.
- If the component has not been deployed, click Set and Deploy Component in the upper part of the page. In the dialog box displayed on the right, click OK. After the deployment is complete, the configurations take effect.
