Updated on 2025-12-30 GMT+08:00
Deleting an Instance
If an instance is abnormal, you can perform the following operations to delete it. You are advised to delete only the abnormal instances.
This operation will forcibly delete the instance. Ensure that data has been backed up or data loss risk assessment has been completed. Deleted instances cannot be restored. Exercise caution when performing this operation.
  1. Log in to CAE.
  2. Choose Instance List.
  3. Select the target environment and application from the drop-down lists in the upper part of the page, and click the target component.
  4. Select the target instance and click Delete in the Operation column.
  5. In the displayed dialog box, click OK.
    Figure 1 Deleting an instance
