Viewing an Instance
A CAE component instance is the minimum running and deployment unit of a component, and tends to be used for a single application process. In CAE, an application consists of one or more application components, and each application component can be deployed and run independently. A component instance is the basic unit for independent deployment and running. It implements a specific service feature of an application.
After a component is created, you can view the instance details on the Instance List page, including the instance name, running status, and creation time.
- Log in to CAE.
- Choose Instance List.
- Select the target environment and application from the drop-down lists in the upper part of the page, and click the target component.
- View the instance name and running status. Figure 1 Instance list
