- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
On this page
Configuring Certificates
You can bind up to 10 certificates.
Adding a Certificate
- Log in to CAE.
- Choose System Settings.
- Click Edit in the Certificates module.
- Click Add Certificate.
- Enter a certificate name For example, test-1.
- Upload Server Certificate Content and Server Private Key Content.
- Click OK.
Editing a Certificate
- Log in to CAE.
- Select the target certificate and click Edit in the Operation column.
- Edit Server Certificate Content and Server Private Key Content.
Figure 1 Editing a certificate
- Click OK.
Deleting a Certificate
- Log in to CAE.
- Select the target certificate and click Delete in the Operation column.
- If Deleted is displayed, the certificate is deleted.
If Failed to unbind xx is displayed when you delete a certificate, choose Component Configurations > Access Mode > Forwarding Policy to check whether the certificate is in use.
Parent topic: System Settings
