- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Authorizing a Source Code Repository
Creating an Authorization
- Log in to CAE.
- Choose System Settings.
- Click Edit in the Source Code Repository Authorizations module.
- Click Create Authorization, select the required source code repository by referring to Table 1, and set parameters.
Table 1 Authorization parameters Parameter
*Authorization
Authorization name, which cannot be changed after being created.
*Repository Type
The following official repositories are supported:
- GitHub (https://github.com)
Authorization mode: OAuth or private token.
- Bitbucket (https://bitbucket.org)
Authorization mode: OAuth or private Bitbucket.
- GitLab (https://gitlab.com)
- Click OK.
Figure 1 Creating a source code repository authorization
- In the Service Statement dialog box, select I understand that the source code building function of the ServiceStage service collects the information above and agree to authorize the collection and use of the information. Click OK.
- On the Authorized Source Code Repository page, you can view the authorization information about the authorized source code repositories, including the authorization name, status, type, repository username, authorization mode, creation time, and update time.
Re-authorizing a Source Code Repository
- Log in to CAE.
- Select the target authorization and click Re-authorize in the Operation column.
During re-authorization, the code source repository cannot be changed. You can only select another authorization mode.
- Click OK.
Deleting an Authorization
- Log in to CAE.
- Use either of the following methods to delete an authorization:
- Batch deletion
- Select the target authorized source code repositories and click to delete Bulk Delete.
Figure 2 Batch deletion
- In the displayed dialog box, enter DELETE and click OK.
- Individual deletion
- Select the target authorized source code repository and click Delete in the Operation column.
- Batch deletion
