Help Center/
API Gateway/
User Guide/
Viewing Metrics and Configuring Alarms/
Configuring an Alarm Rule
Updated on 2025-09-26 GMT+08:00
You can create alarm rules to monitor the status of your APIs.
- Go to the APIG console.
- Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
- Click a group name to go to the Group Information page.
- On the Monitoring area of the APIs tab, click More to access the Cloud Eye console. Then create an alarm rule. For details, see Creating an Alarm Rule.
Parent topic: Viewing Metrics and Configuring Alarms
