Adding a Gateway Response
Updated on 2024-04-03 GMT+08:00
A gateway response is displayed if APIG fails to process an API request. APIG provides a set of default responses and also allows you to create gateway responses with custom status codes and content, on the API Groups page. The response content must be in JSON format.
For example, the content of a default gateway response is as follows:
{"error_code": "$context.error.code", "error_msg": "$context.error.message", "request_id": "$context.requestId"}
You can add a response with the following content:
{"errorcode": "$context.error.code", "errormsg": "$context.error.message", "requestid": "$context.requestId","apiId":"$context.apiId"}
You can add more fields to or delete existing fields from the JSON body.
  • The default gateway responses provided by APIG can be edited.
  • You can create gateway responses and configure different responses for APIs in the same API group.
  • The type of a gateway response cannot be changed. For details, see Response Types.
  • Gateway responses can contain the API gateway context variables (starting with $context). For details, see APIG Context Variables.
You have created an API group.
  1. Access the shared gateway console.
  2. In the navigation pane, choose API Publishing > API Groups.
  3. Locate the API group for which you want to create or modify a gateway response, and click the group name to go to the API group details page.
  4. Click the Gateway Responses tab and create a gateway response.
    • To edit a response, click the Edit button in the upper right corner and modify the status code and content of the response.
    • You can modify only the status code and content of a default or custom gateway response, and you cannot change the response type.
    • Error information and other response details can be obtained using variables. For details about the supported variables, see Table 2.
Response Types
Table 1 lists the response types supported by APIG. You can define status codes of responses to meet your service requirements.
Table 1 Error Response types supported by APIG
Response Name
Default Status Code
Access Denied
403
Access denied. For example, the access control policy is triggered or an attack is detected.
Authorizer Configuration Error
500
A custom authorizer error has occurred. For example, communication failed or an error response was returned.
Authorizer Failed
500
The custom authorization failed.
Incorrect Identity Source
401
The identity source of the custom authorizer is missing or invalid.
Authentication Failure
401
IAM or app authentication failed.
Identity Source Not Found
401
No identity source has been specified.
Backend Timeout
504
Communication with the backend service timed out.
Backend Unavailable
502
The backend service is unavailable due to communication error.
Default 4XX
Another 4XX error occurred.
Default 5XX
Another 5XX error occurred.
No API Found
404
No API is found.
Incorrect Request Parameters
400
The request parameters are incorrect or the HTTP method is not supported.
Request Throttled
429
The request was rejected due to request throttling.
Unauthorized App
401
The app you are using has not been authorized to call the API.
Table 2 Variables that can be used in response message body
Variable
$context.apiId
API ID.
$context.appId
ID of the app that calls the API.
$context.requestId
Request ID generated when the API is called.
$context.stage
Deployment environment in which the API is called.
$context.sourceIp
Source IP address of the API caller.
$context.authorizer.frontend.property
Values of the specified attribute–value pairs mapped to the context in the frontend custom authorizer response
$context.authorizer.backend.property
Values of the specified attribute–value pairs mapped to the context in the backend custom authorizer response
Error message.
$context.error.code
Error code.
$context.error.type
Error type.
