Billing Items
Yearly/Monthly
You are billed for the following items of COC on a yearly/monthly basis.
| Package Type | Package Description | Billing Item | Billing Formula | Purchase and Use Restrictions |
| Multi-cloud Management and Optimization | Manages AWS, Alibaba Cloud, and on-premises IDC resources and provides optimization recommendations. (Huawei Cloud resources are free of charge.) | Number of instances | Number of instances to purchase × Unit price× Required duration | Minimum purchase quantity: 200 instances. Specification change step: 50 instances Only the compute, database, container, and IDC instances of other cloud vendors are charged. |
| Fault Management | Provides fault management functions, such as management of data sources, alarm conversion rules, incidents, alarms, war rooms, and issue improvement tickets. | Number of pairs of alarm conversion rules and contingency plans | Pairs of conversion rules and contingency plans to purchase × Unit price × Required duration | Minimum purchase quantity: 50 pairs. Specification change step: 10 pairs. Except for alarm conversion rules and contingency plans, other fault management functions are not restricted. |
| Change Management | Provides change management functions, such as change calendar, change configurations, change control, change interception, and violation audit. | Number of change tickets | Number of change tickets to purchase × Unit price × Required duration | Minimum purchase quantity: 200 tickets. Specification change step: 100 tickets. Except for change tickets, the usage of other change management functions is not limited. |
| O&M BI Dashboard | Provides subject dashboards such as fault, change, and monitoring alarm dashboards, and provides online report download and subscription functions. | O&M BI Dashboard | Unit price × Required duration | / |
| Fault Drills (Basic Edition) | Provides drill templates and drill tasks, and supports drill fault injection into applications. | / | Unit price × Required duration | A maximum of 20 drill tasks can be performed in a month. |
| Fault Drills (Professional Edition) | Supports all the functions in the resilience center, such as failure modes, drill plans, drill tasks (including process visualization and drill reports), contingency plans, resilience assessment, and PRRs. | / | Unit price × Required duration | The usage is not limited. |
| COC (Professional Edition) | Provides product capabilities such as resource management and O&M, fault management, change management, resilience improvement, and O&M BI dashboard. | Number of instances | Number of instances to purchase × Unit price × Required duration | The usage is not limited in the scenario where instances are not required. The instance operation scenario is limited by the number of instances. |
In the fault management package:
- Alarm conversion rules: The quota is calculated for all existing rules of the current account. For example, if a user has created 20 rules and the user purchases a fault management package with the conversion rule quota of 50 after COC billing starts, the 20 rules will be included in the current quota 50.
- Contingency plans: The quota is calculated based on the existing custom contingency plans created by the current account. For example, if a user has created 20 custom contingency plans and the user purchases a fault management package with the contingency plan quota of 50 after the COC billing starts, the 20 contingency plans will be included in the current quota 50.
The product functions of each COC offering package are as follows:
| Package | Function Path | Function |
| Multi-cloud Management and Optimization | Resources > Application and Resource Management | Multi-cloud configurations, display of resources from other cloud vendors and IDCs, and application association |
| Fault Management | Fault Management | Alarm management (aggregated alarms and alarm rules), incident management, war rooms, improvement ticket management, issue management, alarm conversion rules, and data source integration management (non-Huawei Cloud alarm sources) SLA management, SLO management, and mobile app management |
| Basic Configurations | Functions of the Incident Process and Issue Process tab pages under the Process Management menu. | |
| Change Management | Change Management | All functions under Change Ticket Management |
| Basic Configuration > Process Management | The Change Scenarios tab page under the Process Management menu | |
| O&M BI Dashboard | Overview > O&M BI Dashboard | O&M BI dashboard |
| Basic Configurations > Report Subscription | Reports can be subscribed. | |
| Fault Drills (Basic Edition) | Resilience Center > Chaos Drills | Drill tasks (20 executions of drill tasks are allowed for each month. If you do not use up the quota of 20 in a month, the remaining executions cannot be retained to the next period.) and drill templates |
| Fault Drills (Professional Edition) | Resilience Center | All functions under Resilience Center |
| COC (Professional Edition) | / | Basic COC functions that are free of charge, multi-cloud management and optimization, fault management, change management, O&M BI dashboard, and fault drills (professional edition) |
Pay-per-Use Billing Items
Pay-per-Use billing items for COC are listed as follows:
| Billing Item | Billing Formula | Description |
| OS version changes | Unit price × Number of instances for each change | You are charged only when the OS version change service ticket is successfully executed. |
| Number of job execution steps for scenario-specific jobs | Unit price × Number of execution steps | You are charged based on the number of steps required for the execution of a custom, public, or scheduled job. This is free of charge. |
Billing Examples
Assume that you purchased a change management package with 200 change tickets for one month at 10:49:04 on February 1, 2025, and manually renewed the package for one month before it expires:
- The first billing cycle is from 10:49:04 on February 1, 2025 to 23:59:59 on March 1, 2025.
- The second billing cycle is from 23:59:59 on March 1, 2025 to 23:59:59 on April 1, 2025.
You can create up to 200 change tickets in each of the two billing cycles. However, any unused tickets from the first cycle will expire and cannot be transferred to the second cycle.
