Creating a CCE Standard Cluster
On the CCE console, you can easily create Kubernetes clusters. After a cluster is created, the master node is hosted by CCE. You only need to create worker nodes. In this way, you can implement cost-effective O&M and efficient service deployment.
Precautions
  • After a cluster is created, the following items cannot be changed:
    • Cluster type
    • Number of master nodes in the cluster
    • AZ of a master node
    • Network configurations of the cluster, such as the VPC, subnet, Service CIDR block, and kube-proxy settings
    • Network model. For example, change Tunnel network to VPC network.
Step 1: Log In to the CCE Console
  1. Log in to the CCE console.
  2. On the Clusters page, click Create Cluster in the upper right corner.
Step 2: Configure the Cluster
On the Create Cluster page, configure the parameters.
Basic Settings
Cluster Name
Enter a cluster name. Cluster names under the same account must be unique.
Cluster Version
Select the Kubernetes version used by the cluster.
Cluster Scale
Select a cluster scale for your cluster as required. These values specify the maximum number of nodes that can be managed by the cluster.
Master Nodes
Select the number of master nodes. The master nodes are automatically hosted by CCE and deployed with Kubernetes cluster management components such as kube-apiserver, kube-controller-manager, and kube-scheduler.
  • 3 Masters: Three master nodes will be created for high cluster availability.
  • Single: Only one master node will be created in your cluster.
You can also select AZs for the master nodes. By default, AZs are allocated automatically for the master nodes.
  • Automatic: Master nodes are randomly distributed in different AZs for cluster DR. If the number of available AZs is less than the number of nodes to be created, CCE will create the nodes in the AZs with sufficient resources to preferentially ensure cluster creation. In this case, AZ-level DR may not be ensured.
  • Custom: Master nodes are deployed in specific AZs.
    If there is one master node in your cluster, you can select one AZ for the master node. If there are multiple master nodes in your cluster, you can select multiple AZs for the master nodes.
    • AZ: Master nodes are deployed in different AZs for cluster DR.
    • Host: Master nodes are deployed on different hosts in the same AZ for cluster DR.
    • Custom: Master nodes are deployed in the AZs you specified.
Network Settings
The network settings cover nodes, containers, and Services. For details about the cluster networking and container network models, see Overview.
Table 1 Cluster network settings
VPC
Select the VPC to which the cluster belongs. If no VPC is available, click Create VPC to create one. The value cannot be changed after the cluster is created.
Subnet
Select the subnet to which the master nodes belong. If no subnet is available, click Create Subnet to create one. The value cannot be changed after the cluster is created.
Table 2 Container network settings
Network Model
Select VPC network or Tunnel network for your CCE standard cluster.
For more information about their differences, see Overview.
Container CIDR Block (configured for CCE standard clusters)
Configure the CIDR block used by containers. The value determines the maximum number of containers in your cluster.
Table 3 Service network settings
Service CIDR Block
Configure the Service CIDR blocks for containers in the same cluster to access each other. The value determines the maximum number of Services you can create. The value cannot be changed after the cluster is created.
Request Forwarding
Select IPVS or iptables for your cluster. For details, see Comparing iptables and IPVS.
  • iptables is the traditional kube-proxy mode. This mode applies to the scenario where the number of Services is small or a large number of short connections are concurrently sent on the client. IPv6 clusters do not support iptables.
  • IPVS allows higher throughput and faster forwarding. This mode applies to scenarios where the cluster scale is large or the number of Services is large.
(Optional) Advanced Settings
Certificate Authentication
  • If Automatically generated is selected, the X509-based authentication mode will be enabled by default. X509 is a commonly used certificate format.
  • If Bring your own is selected, the cluster can identify users based on the header in the request body for authentication.
    Upload your CA root certificate, client certificate, and private key.
    CAUTION:
    • Upload a file smaller than 1 MB. The CA certificate and client certificate can be in .crt or .cer format. The private key of the client certificate can only be uploaded unencrypted.
    • The validity period of the client certificate must be longer than five years.
    • The uploaded CA root certificate is used by the authentication proxy and for configuring the kube-apiserver aggregation layer. If any of the uploaded certificates is invalid, the cluster cannot be created.
    • Starting from v1.25, Kubernetes no longer supports certificate authentication generated using the SHA1WithRSA or ECDSAWithSHA1 algorithm. The certificate authentication generated using the SHA256 algorithm is supported instead.
CPU Management
If enabled, exclusive CPU cores can be allocated to workload pods. For details, see CPU Policy.
Overload Control
After this function is enabled, concurrent requests will be dynamically controlled based on the resource demands received by master nodes to ensure the stable running of the master nodes and the cluster. For details, see Enabling Overload Control for a Cluster.
Resource Tag
You can add resource tags to classify resources. A maximum of 20 resource tags can be added.
You can create predefined tags on the TMS console. The predefined tags are available to all resources that support tags. You can use predefined tags to improve the tag creation and resource migration efficiency.
You can enter description for the cluster. A maximum of 200 characters are allowed.
Step 3: Select Add-ons
Click Next: Select Add-on. On the page displayed, select the add-ons to be installed during cluster creation.
Basic capabilities
Add-on Name
CCE Container Network (Yangtse CNI)
This is the basic cluster add-on. It provides network connectivity, Internet access, and security isolation for pods in your cluster.
CCE Container Storage (Everest)
This add-on (CCE Container Storage (Everest)) is installed by default. It is a cloud native container storage system based on CSI and supports cloud storage services such as EVS.
CoreDNS
This add-on (CoreDNS) is installed by default. It provides DNS resolution for your cluster and can be used to access the in-cloud DNS server.
Observability
CCE Node Problem Detector
(Optional) If selected, this add-on (CCE Node Problem Detector) will be automatically installed to detect faults and isolate nodes for prompt cluster troubleshooting.
Step 4: Configure Add-ons
Click Next: Add-on Configuration.
Basic capabilities
Add-on Name
This add-on is unconfigurable.
This add-on is unconfigurable. After the cluster is created, choose Add-ons in the navigation pane of the cluster console and modify the configuration.
CoreDNS
Observability
Step 5: Confirm the Configuration
After the parameters are specified, click Next: Confirm configuration. The cluster resource list is displayed. Confirm the information and click Submit.
It takes about 5 to 10 minutes to create a cluster. You can click Back to Cluster List to perform other operations on the cluster or click Go to Cluster Events to view the cluster details.
Related Operations
