CCE.Storage.SFS
Element Description
The CCE.Storage.SFS element corresponds to file storage volumes in the CCE storage management function. This type of resources must be used together with CCE clusters.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
size
No
Storage space size, in GB. The default value is 80.
Type: integer
Default: 10
Value Constraint: The value ranges from 1 to 511800.
Suggestion: Set the value based on the live environment.
k8sManifest
No
K8s-native manifest object of the SFS, which can be used to replace other configuration items in SFS resource creation
Type: dict
Value Constraint: The value must meet the Kubernetes specifications.
Suggestion: For details, see the sample or CCE documentation.
name
No
Name of the CCE SFS file system, which is mounted to the container
Type: string
Value Constraint: Enter 1 to 24 characters, starting with a letter and ending with a letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed. The value must meet regular expression (^$)|(^[a-z]([-a-z0-9]*[a-z0-9])?$).
Suggestion: Customize the value.
clusterId
No
ID of the cluster which is associated with the storage system
Type: Cloud.CCE.Cluster.Id
Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters.
Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID.
volumeId
No
Cloud storage volume ID when you import a volume
Type: string
Value Description: Customize the value.
Suggestion: None
deleteVolume
No
Whether to delete the cloud storage when you import a volume and delete a PVC
Type: boolean
Default: False
Value Constraint: The options are true and false.
Suggestion: None
namespace
No
Namespace where the resource is located
Type: string
Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed.
Suggestion: Log in to the CCE console, and choose Resource Management > Namespaces. View and select the target namespace.
Relationships Between Elements
Table 2 Relationship description
Target
Dependency
DCS.Redis
Dependency
RDS.MySQL
Dependency
OBS.Bucket
Dependency
CCE.Storage.SFS
Dependency
CCE.Storage.OBS
Dependency
CCE.NodePool
Dependency
CCE.Pod
Inclusion
CCE.Cluster
Return Value
Property
Type
status
string
Status of the SFS file system
clusterId
string
ID of the cluster which is associated with the SFS file system
refID
string
UID of the SFS file system
refName
string
Name of the SFS file system
Blueprint Example
Example 1:
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  storage-name:
    default: my-evc-storage
node_templates:
  my-storage:
    type: Cloud.CCE.Storage.SFS
    properties:
      name:
        get_input: storage-name
Example 2: Custom K8s Manifest for Orchestration
  • For clusters of version 1.13 or earlier, the example configuration of the YAML file is as follows:
    node_templates:
      my-storage:
        properties:
          apiVersion: v1
          kind: PersistentVolumeClaim
            annotations:
              volume.beta.kubernetes.io/storage-class: nfs-rw
              volume.beta.kubernetes.io/storage-provisioner: flexvolume.com/fs
            namespace: default
            accessModes:
            - ReadWriteMany
            resources:
              requests:
                storage: 10Gi
