- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
CCE.Pod
Element Description
The CCE.Pod element is used to create a pod in the Kubernetes cluster on the CCE.
Element Properties
Property |
Mandatory |
Descripiton |
k8sManifest |
Yes |
Native YAML file content of a Kubernetes object Type: dict Value Description: Customize the value. You are advised to use a public image, which is uploaded to the image repository and whose type is set to public, and not to change the name under the metadata during an update. Value Constraint: This field cannot be left blank. |
name |
No |
Pod name Type: string Value Description: Customize the value, for example, my-pod. Value Constraint: The value supports a maximum of 63 characters and must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. |
clusterId |
No |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. |
namespace |
No |
Namespace where the resource is located Type: string Value Description: It must be a valid namespace in the cluster, for example, default. Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. Suggestion: Log in to the CCE console, and choose Resource Management > Namespaces. View and select the target namespace. |
Relationships Between Elements
Description |
Target |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Inclusion |
Return Value
Property |
Type |
Description |
refName |
string |
Pod name |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 node_templates: ccepxbto: type: Cloud.CCE.Pod properties: k8sManifest: kind: Pod spec: containers: - image: get_input: ccepxbto_k8sManifest_spec_containers_0_image imagePullSecrets: - name: default-secret name: test restartPolicy: Always imagePullPolicy: Always apiVersion: v1 metadata: labels: name: pod-test name: pod-test name: get_input: ccepxbto_name clusterId: get_input: ccepxbto_clusterId namespace: get_input: ccepxbto_namespace inputs: ccepxbto_k8sManifest_spec_containers_0_image: description: Container image label: Pod ccepxbto_name: description: Pod name label: Pod ccepxbto_clusterId: description: ID of the cluster where the resource is located label: Pod ccepxbto_namespace: description: Namespace where the resource is located label: Pod outputs: name: value: get_attribute: - ccepxbto - refName description: pod name
