CCE.NodePool
Element Description
The CCE.NodePool element is used to deploy Kubernetes node resources at the PaaS layer. You can use it to orchestrate cloud resources on nodes.
Element Properties
Table 1 Property Description
Property
Mandatory
dataVolumes
Yes
Data disk of a created node
Type: CCE.DataVolume array
Value Description: Customize the value, for example, [{"volumeType":"SATA","size":100}].
Value Constraint: Array format. Currently, only one object is supported.
Suggestion: Customize the value.
availabilityZone
Yes
AZ where a node is located
Type: Cloud.ECS.AvailabilityZone.Name
Value Description: AZ where the to-be-created ECS is located. The name of the AZ needs to be specified, for example, ae-ad-1a. For details, see the Regions and Endpoints page.
Value Constraint: The value varies depending on regions.
Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console.
name
Yes
Name of the created node
Type: string
Value Description: Customize the value.
Value Constraint: The value contains 4 to 32 characters and must start with a lowercase letter. Only lowercase letters, digits, and underscores (_) are allowed.
Suggestion: Customize the value. Generally, the stack name is used as the node name.
publicKey
No
Public key of the key pair. If the node pool is billed in the yearly/month mode, this parameter is mandatory.
Type: Cloud.ECS.KeyPair.PublicKey
Value Description: Selects an existing public key.
Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console based on the value of sshKeyName.
postInstall
No
Node post-installation script
Type: string
Value Constraint: The script you specify here will be executed after K8S software is installed.
Suggestion: The script is usually used to modify Docker parameters.
labels
No
Node label
Type: CCE.Labels array
Value Description: Customize the value, for example, {"app": "aos"}.
Suggestion: You can enter multiple key-value pairs.
clusterId
No
ID of the cluster to which the resource belongs
Type: Cloud.CCE.Cluster.Id
Value Description: ID of an existing or new container cluster.
Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters.
Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID.
preInstall
No
Node pre-installation script
Type: string
Value Constraint: The script you specify here will be executed before K8S software is installed. Note that if the script is incorrect, K8S software may not be installed successfully.
Suggestion: The script is usually used to format data disks.
publicIp
No
Virtual IP address of the created node
Type: CCE.PublicIP
Value Description: Customize the value, for example, {"eip":{"bandwidth:{"shareType":PER}, 5_sbgp"}}.
Default: {}
Value Constraint: Only one elastic IP address can be defined for each node.
instances
Yes
Number of created nodes
Type: integer
Value Description: Customize the value. The value ranges from 1 to 50.
Default: 1
Value Constraint: {u'in_range': [1, 50]}
Suggestion: Set the value based on the live environment.
rootVolume
Yes
System disk of the created node
Type: ECS.RootVolume
Value Description: Customize the value, for example, {"volumeType":"SATA","size":40}.
Default: {u'volumeType': u'unset', u'size': 40}
os
No
Node OS
Type: string
Value Description: ["EulerOS 2.2", "CentOS 7.4"]
Default: EulerOS 2.2
Value Constraint: {u'valid_values': [u'CentOS 7.4', u'EulerOS 2.2']}
nodePasswd
No
Password of the node root user
Type: password
Value Constraint: 1. The parameter must be written into inputs and set using the get_input function. 2. The value must not be a weak password. Enter 8 to 26 characters. Only uppercase and lowercase letters, digits, and special characters !@$%^-_=+[{}]:,./? are allowed. The value must contain at least two types of characters.
Suggestion: You are advised to use the get_input function to obtain the value and avoid plaintext passwords to ensure security.
flavor
Yes
Container node specification
Type: Cloud.CCE.Node.Flavor.Name
Value Description: ID of the system flavor of the cloud server to be created. For details about the available flavors, see Elastic Cloud Server Service Overview. It is advised to use the get_input function to pass this parameter.
Suggestion: Select the node specification during node creation on the CCE console. In the node template, you can set the inputs to specify the node specification.
sshKeyName
No
Key pair used for logging in to a node, which needs to be kept properly
Type: Cloud.ECS.KeyPair.Name
Value Description: It must be created on the ECS console in advance.
Suggestion: 1. You are advised to use the get_input function to set the parameter so that you can select a value when using the template. 2. Search for the information on the ECS console, and enter the information accordingly.
annotations
No
Node annotations
Type: dict
Relationships Between Elements
Table 2 Relationship description
Target
Inclusion
CCE.Cluster
Connected
ECS.KeyPair
Connected
CCE.Storage.OBS
Connected
CCE.Pod
Connected
CCE.NodePool
Connected
CCE.Storage.SFS
Return Value
Property
Type
floatingIpId
string
ID of an elastic IP address
clusterId
string
Cluster ID
refName
string
Node name
privateIp
Array
List of private elastic IP addresses
publicIp
Array
List of public elastic IP addresses
refID
string
Node ID
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
node_templates:
  ccenp1ep:
    type: Cloud.CCE.NodePool
    properties:
      dataVolumes:
        - volumeType: SATA
      instances: 1
      rootVolume:
        volumeType: SATA
      flavor:
        get_input: ccenp1ep_flavor
      sshKeyName:
        get_input: ccenp1ep_sshKeyName
inputs:
  ccenp1ep_flavor:
    description: Container node specifications
    label: ''
  ccenp1ep_sshKeyName:
    description: Key pair used for logging in to a node. Keep the key pair properly.
    label: ''
