- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
CCE.HelmRelease
Element Description
Helm is a type of Kubernetes-based package specifications provided by CCE. The CCE.HelmRelease element is a deployment instance of the Helm package.
Element Properties
Property |
Mandatory |
Descripiton |
name |
Yes |
Name of the created CCE.HelmRelease Type: string Value Description: Customize the value, for example, my_release. Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. |
clusterId |
No |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: This parameter is optional. You can set this parameter when creating a stack. |
namespace |
No |
Namespace where the resource is located Type: string Value Description: namespace of a cluster Default: default Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. Suggestion: This parameter is optional. You can set this parameter when creating a stack. |
chart |
Yes |
Chart information about the Helm application Type: CCE.HelmChart Value Description: Information includes the chart package name and version number, which can be obtained from Charts in the navigation pane on the CCE console. Default: {u'version': u'', u'name': u''} Suggestion: Set the value based on the helm application to be orchestrated. |
values |
Yes |
Input value of the Helm application Type: dict Value Description: Customize the value. Default: {} Value Constraint: Composite structure, which is similar to {"key": "value"}, where value can be nested. Suggestion: For your own applications, enter the corresponding value. |
Relationships Between Elements
Description |
Target |
Connected |
Connected |
Connected |
Connected |
Inclusion |
Return Value
Property |
Type |
Description |
clusterId |
string |
Cluster ID |
refName |
string |
Release name |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 inputs: release_name: default: "release" cluster_id: default: "25f511bc-00f7-11e8-958d-0255ac101a5a" namespace: default: "default" chart_name: default: "redis" chart_version: default: "1.0.0" app_image: default: "10.125.5.235:20202/test/redis:3.2.8" config_image: default: "10.125.5.235:20202/test/redis-conf:3.2.8" service_port: type: integer default: 6379 node_templates: redis-helm: type: Cloud.CCE.HelmRelease properties: name: {get_input: release_name} chart: name: {get_input: chart_name} version: {get_input: chart_version} clusterId: {get_input: cluster_id} namespace: {get_input: namespace} values: chartimage: app_image: {get_input: app_image} config_image: {get_input: config_image} format1: redis_master_replicas: 1 redis_sentinel_replicas: 1 redis_slave_replicas: 1 format2: redis_master_replicas: 1 redis_sentinel_replicas: 1 redis_slave_replicas: 2 highavailable: redis_replication_enabled: true redis_sentinel_replicas: 1 redis_slave_replicas: 1 servicestorage: service: instance: "127.0.0.1" service_port: {get_input: service_port} type: "ClusterIP" storage: enabled: false kind: "sas" size: "10Gi"
