Help Center/ Object Storage Service/ User Guide/ Data Management/ Lifecycle Management/ Using Lifecycle Rules to Delete or Transition Objects
Updated on 2026-11-24 GMT+08:00
This section describes how to configure lifecycle rules to transition objects between storage classes and delete objects.
Because multi-AZ redundancy is not supported for Archive and Deep Archive storage, you cannot transition objects in a multi-AZ bucket to Archive or Deep Archive through lifecycle rules.
Transitioning Objects Using Lifecycle Rules
Figure 1 Transitioning objects using lifecycle rules
As shown in Figure 1, OBS allows you to use lifecycle rules to transition objects as follows:
  • From Standard to Infrequent Access, Archive, or Deep Archive
  • From Infrequent Access to Archive or Deep Archive
  • From Archive to Deep Archive
When a lifecycle rule is applied, OBS transitions objects based on the versioning state of your bucket.
Each object in an unversioned bucket has only one version. You can use lifecycle rules to transition such objects.
Table 1 Transitioning objects in an unversioned bucket
Action Type
Effect of Action
Timer Start Time
Transitioning between storage classes
The object is transitioned to the target storage class.
Time when an object is uploaded
If versioning is not enabled for a bucket, there are no historical versions in the bucket. Therefore, the NoncurrentVersionTransition field is invalid.
You can use lifecycle rules to transition the current and historical versions of objects in a versioning-enabled bucket.
Table 2 Transitioning objects in a versioning-enabled bucket
Action Type
Effect of Action
Timer Start Time
Transitioning the current version
  • If the current version is not a delete marker version, it is transitioned to the target storage class.
  • If the current version is a delete marker, no action is taken.
Time when the current version is uploaded
Transitioning a historical version
  • If the historical version is not a delete marker, it is transitioned to the target storage class.
  • If the historical version is a delete marker, no action is taken.
Time when the current version becomes a historical version
You can use lifecycle rules to transition the current and historical versions of objects in a versioning-suspended bucket.
Table 3 Transitioning the current and historical versions of objects in a versioning-suspended bucket
Action Type
Effect of Action
Timer Start Time
Deleting Objects Using Lifecycle Rules
OBS uses lifecycle rules to delete objects based on the versioning state of your bucket.
If versioning is not enabled for a bucket, each object has only one version. You can use lifecycle rules to delete objects and fragments from this bucket.
Table 4 Deleting files from a versioning-disabled bucket
Action Type
Effect of Action
Deleting an object
The object is permanently deleted and cannot be restored.
Deleting fragments
The fragments are permanently deleted and cannot be restored.
If versioning is not enabled for a bucket, the bucket does not have historical versions or delete markers. Therefore, the NoncurrentVersionExpiration and ExpiredObjectDeleteMarker fields are invalid.
You can use lifecycle rules to delete the current version, historical versions, expired delete markers, and fragments of objects from a versioning-enabled bucket.
Table 5 Deleting files from a versioning-enabled bucket
Action Type
Effect of Action
Deleting the current version of an object
  • If the current version is not a delete marker, a delete marker with a unique version ID is created. The current version becomes a historical version, and the delete marker becomes the current version.
Deleting a historical version of an object
The historical version is deleted and cannot be restored.
Deleting an expired delete marker
The expired delete marker is deleted. After all historical versions of an object are deleted, the current delete marker version will be deleted to improve the List performance.
Deleting fragments
You can use lifecycle rules to delete the current version, historical versions, expired delete markers, and fragments of objects from a versioning-suspended bucket.
Table 6 Deleting files from a versioning-suspended bucket
Action Type
Effect of Action
  • If the current version is not a delete marker and the version ID is not null, the current version becomes a historical version, and the delete marker with a null ID becomes the current version.
    After versioning is suspended, a newly uploaded object will have the version ID of null. If the newly uploaded object has the same name as an existing object with a null version ID, this new object will overwrite the existing object. For details, see Versioning.
  • If the current version is not a delete marker version and the current version ID is null, the delete marker version with the null ID overwrites the current version. The delete marker then becomes the current version, and the overwritten version cannot be recovered.
Deleting fragments
Overlapping Lifecycle Rules
You can configure multiple lifecycle rules for a bucket. If the filter conditions of rules overlap, one object can match more than one rule. Two rules overlap if any of the following applies:
  • A rule's prefix filter is empty. This rule overlaps with all other rules.
  • Rule A and rule B have the same prefix filter.
  • The prefix filter of rule A is a substring of the prefix filter of rule B.
If a rule to be created overlaps with an existing one, the rule must meet the following requirements or it will fail to be created:
  • The prefix and the tag cannot be the same as those of the existing rule at the same time.
  • The rule uses either Days or Date.
  • The actions on an object take place in the following order: Transition to Infrequent Access > Transition to Archive > Transition to Deep Archive > Delete the object upon expiration.
  • Overlapping rules cannot be configured with the same action. For example, you cannot have two rules that both delete objects or two rules that both transition objects to Infrequent Access, Archive, or Deep Archive.
  • If there is an overlapping rule, the settings for deleting expired versions, fragments, and expired delete markers cannot be configured at the same time. Otherwise, there will be conflicts. For example:
Important Notes
  • Encrypted objects remain encrypted when their storage class is transitioned.
  • Minimum storage duration
    The minimum storage duration is the minimum billable storage duration. This means that objects will be billed for the minimum storage duration even if they are not stored for that long. For example, if an object is transitioned to Archive after being stored in Infrequent Access for 20 days, it will be billed for the storage of 30 days (the minimum storage duration for Infrequent Access).
    Item
    Standard
    Infrequent Access
    Archive
    Deep Archive
    N/A
    30 days
    90 days
    180 days
Related Operations
Check whether an object version is a delete marker:
  1. In the navigation pane of OBS Console, choose Buckets.
  2. In the bucket list of OBS Console, click the desired bucket to go to the Objects page.
  3. Enable Historical Versions to check whether each object version is a delete marker.
    Historical Versions appears above the object list only when bucket versioning is enabled or suspended.
You can also use the API for listing objects in a bucket or the following SDKs to check whether an object version has a delete marker:
