Updated on 2026-09-10 GMT+08:00
Monitored OBS Events
Functions
You can configure alarm rules on Cloud Eye to monitor critical events or operation events related to your cloud resources. Once configured, Cloud Eye will notify you when the specified events happen.
Namespace
SYS.OBS
Monitored Events
Table 1 OBS events that can be monitored
Event Name
Event ID
Severity
Handling Suggestion
Impact
Create bucket
createBucket
Major
An event is reported when a bucket creation takes place.
After creating a bucket, you are advised to configure a bucket policy or ACL to control access to the bucket.
After a bucket is created, the associated account can access the bucket and upload objects to it.
Delete bucket
deleteBucket
Major
An event is reported when a bucket deletion takes place.
Deleted buckets cannot be recovered. If you still need to use buckets, create a bucket again.
CAUTION:
If you want to reuse the name of a deleted bucket for a new bucket, wait at least 30 minutes after the bucket is deleted.
Deleting buckets may affect your services. Before deleting a bucket, make sure that your services do not depend on it.
Delete bucket policy
deleteBucketPolicy
Major
An event is reported when a bucket policy deletion takes place.
After a bucket policy is deleted, some users may fail to access the associated bucket and the objects in it.
Set bucket ACL
setBucketAcl
Minor
An event is reported when a bucket ACL configuration takes place.
If you do not want an account to access a bucket or the objects in it, you can delete the bucket ACL.
A bucket ACL grants an account the access to the bucket and the objects in it.
Set bucket policy
setBucketPolicy
Minor
An event is reported when a bucket policy configuration takes place.
If you do not need a bucket policy to perform fine-grained access control over a bucket and the objects in it, you can delete the bucket policy.
A bucket policy grants an account some operation permissions for the bucket or the objects in it under certain conditions.
