Restoring an Object from Archive or Deep Archive Storage
You must restore an object in the Archive or Deep Archive storage class before you can download it or access it with a URL.
To learn the costs involved in data restore, see Product Pricing Details.
- If an Archive or a Deep Archive object is being restored, its restore task cannot be suspended or deleted.
- An object being restored cannot be restored again.
- After an object is restored, an object copy in the Standard storage class will be generated. This way, there is an Archive or a Deep Archive object and a Standard object copy in the bucket at the same time. During the restore validity period, you will be charged for the space taken up by both the object and its copy. The copy will be automatically deleted once the restore expires.
- In the navigation pane of OBS Console, choose Object Storage.
- In the bucket list, click the bucket you want to operate to go to the Objects page.
- Select the file you want to restore, and click Restore on the right. The following dialog box shown in Figure 1 is displayed.
You can select multiple files and choose More > Restore above the file list to batch restore them.
Objects that are being restored cannot be added for batch restore.
- Configure the validity period and speed of the restore. The following table describes the parameters.
Table 1 Parameters for restoring objects Parameter
Validity Period
How long the object will remain in the Restored state. It starts once the object is restored. The value is an integer ranging from 1 to 30 (days). The default value is 30.
For example, if you set Validity Period to 20 when restoring an object, 20 days after the object is successfully restored, its status will change from Restored to Unrestored.
Speed
How fast an object will be restored.
- Expedited: Archive objects can be restored within 1 to 5 minutes, and Deep Archive objects can be restored within 3 to 5 hours.
- Standard: Archive objects can be restored within 3 to 5 hours, and Deep Archive objects can be restored within 5 to 12 hours.
- Click OK.
The system checks the file restore status at UTC 00:00 every day. The system starts counting down the expiration time from the time when the latest check is complete.
Related Operations
Within the validity period of a restored object, you can restore the object again. The validity period is then extended because it will start again when the latest restore is complete.
If a restored object is restored again, its expiration time should be later than the time set for the previous restore. Assume that an object is restored on January 1 and will expire 30 days later (on January 30). If the object is restored again on January 10 and is made to be expired earlier than January 30 (less than 20 days later), this restore action is considered invalid.
