Deleting a Bucket
You can delete unwanted buckets on OBS Console to free up the quota of buckets.
- All objects in the bucket have been permanently deleted. A bucket must be emptied before it can be deleted.
Objects under the Objects, Deleted Objects, and Fragments tabs must be all deleted.
- A bucket can only be deleted by the bucket owner.
- In the navigation pane of OBS Console, choose Object Storage.
- In the bucket list, select the bucket you want to delete, and then click Delete on the right.
The name of a deleted bucket can be reused for another bucket or parallel file system at least 30 minutes after the deletion.
- Click OK to confirm the deletion.
Figure 1 Deleting a bucket
