- User Guide
- Best Practices
- FAQs
On this page
Show all
Enabling Log Detection
You have purchased MTD and created a detector in the current region.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
Figure 1 Home page of MTD - Choose Settings > Detection Settings in the left navigation pane.
- Select the target service and click
to enable log detection for the service. If the icon under the service name changes to
, the real-time log detection is successfully enabled.
Figure 2 Log detection enabledNOTE:
- When you enable service log detection for the first time, a dialog box is displayed, asking you to configure a tracker accessing the service logs.
- You can click Create a Tracker to switch to the Tracker List page. For details, see Step 2: Create a Tracker.
- You can click Learn how to view how to create a tracker in the CTS user guide.
Parent topic: Log Detection Management
