Updated on 2026-09-18 GMT+08:00
SQL Reduction Functions
Reduction functions operate on zero or a list of expressions and return a single expression. If no expression is passed as a parameter, the result is NULL. All expressions must be converted to public data types.
  • If all parameters are NULL, the result is NULL. Otherwise, NULL parameters are ignored.
  • If all parameters contain both numbers and strings, they are interpreted as strings.
  • If all parameters are integers, they are interpreted as long integers.
  • If all parameters are numeric and at least one of them is double, all parameters are interpreted as double.
Syntax
GREATEST([expr1, ...])/ LEAST([expr1, ...])
Examples
GREATEST([expr1, ...])/LEAST([expr1, ...])
The GREATEST function returns the maximum value in zero or a list of expressions.
The LEAST function returns the minimum value in zero or a list of expressions.
  1. Example field
    Num: 11785730
  2. Query and analysis statement
    select  Num,GREATEST( "Num"/10,(select count(1)) ),LEAST("Num"/10,(select count(1)))
  3. Query and analysis result
    Table 1 Query and analysis result of reduction functions
    Num
    EXPR$1
    EXPR$2
    11785730
    1178573
